KNIGHTRIDER666RSB
- First Name
- Randy
- Oct 28, 2024
- 0
- 11
- 4
- New Jersey
- 2024 Honda Civic Type R
1st revs out at 36mph, be careful...
Yes 99.99% of 1st gear downshift is going to be for parking lots. Never force it into first. And don't go hard on it in low rpm's.Honestly in general its a bad idea to downshift into 1st imo.
You can get by fine with just being in second, the car makes plenty of torque and these cars aren't NA so you don't need to be high in the rev range to go. I only downshift into 1st when I want to be cheeky to go full WOT but I know what Im doing and I don't do it all the time.
Totally unnecessary and I wouldn't advise someone who is learning a manual to do it at all, even if you are turning. Just drop it into Neutral and then pop it in 2nd gear and go, you can launch the car in 2nd gear and be fine. The only time you should be in 1st gear when you are on the road is if you are in stop and go traffic. 1st gear should be used for parking lots and residential areas.
As what others have said, if you are doing a turn just down shift into the appropriate gear, like 3rd and then use engine braking to get into 2nd, or you can just lower the speed, clutch in and go into second as you turn and feather and give it revs it if you feel like it might stall, or you can just pop it in neutral and than keep the momentum and then shift into 2nd. There is no correct way, it just depends on how sharp the turn is, and you'll get a feel for what speed you can do them in.
That's good to hear, I've been exclusively shifting to 2nd as my lowest gear but get scared I'll bog the engine down and stall. Luckily I've never stalled from that (only forgetting to clutch in at stop lights haha).Honestly in general its a bad idea to downshift into 1st imo.
I agree completely. Only time I shift to first is either complete stop or stop/go traffic. Otherwise I never shift below second in a moving car.Honestly in general its a bad idea to downshift into 1st imo.
I never "downshift" to 1st. Before a turn you want to "engine" brake, meaning downshift before the turn likely to 2nd, then drive through the turn. Use the brake and push in the clutch if you need to slow further, then release the clutch while still in 2nd and continue going forward. If you end up have to slow down to a very slow speed, then yes, go from 2nd to 1st, then release clutch slowly and continue moving forward. However, if you've approached the turn correctly you should be good to travel through in 2nd. If you end up almost coming to complete stop while in 2nd, again use the brake and keep clutch depressed before moving into 1st. I would NEVER use 1st to "engine brake" before a turn.I came upon the problem today, but what's the best way to tackle a turn (left or right) where you don't want to slow down too much? Was slowing down from 45 to like 10 and ended up just dipping into neutral and using momentum around the turn. Thought maybe I should've downshifted to like 2nd and used my gas pedal to control my turn rather than rely on the cars pre existing speed.
Doesn't that damage the throw out bearing for the clutch? Like if I'm in stop and go traffic (fast enough to only be stopped for a second) and need to be in first to keep moving, would that not be riding the clutch? Or is that how you're supposed to use the clutch? I had to do it it the other day while driving in light traffic, but wasn't sure if it was good practice.The only time I am in neutral is if I am stopped and I want to give my clutch leg a rest. You don't want to be in neutral while moving slowly as you may need to accelerate again and you don't want to be searching for a gear. You kind of want to anticipate and be in the appropriate gear for the situation. That's why you can use the clutch at other times to manage the situation.
yes, it will always be a bit jerky. There is a bit of rev hang between shifts. It is inherent to manuals and part of the joy - trying to nail a perfect shift. Comes with practice of managing the clutch, shifting at the optimal revs and managing the gas pedal all in a coordinated manner. The manual will never feel as smooth as a quick shifting automatic. There are some drivers who are excellent at managing the gas pedal input, clutch release and shifting at best rev point. They can execute some very smooth shifts. Still it's a manual so it will always have some "jerky" feeling here and there as you execute a quick shift. Lastly, the car is front wheel drive so you're going to feel the engine "buck" a little because it's connected directly to the front axle.That's good to hear, I've been exclusively shifting to 2nd as my lowest gear but get scared I'll bog the engine down and stall. Luckily I've never stalled from that (only forgetting to clutch in at stop lights haha).
I was curious about whether shifting the car aggressively will always be shaky. It's one thing to do a smooth shift after a 2nd pull to 3rd, but if I'm on a track and I want to go as fast as possible, will the car always need to be shifted in a jerky way? I ask because my buddy who also drives stick is jerkier than I am when going from a stop to 1st (and 2nd), and he had more experience than me. I also read. Reddit post saying that would be the case for fast shifts.
You wont stall the car, and if you feel it bogging or anticipate it, just clutch in and feather as you turn.That's good to hear, I've been exclusively shifting to 2nd as my lowest gear but get scared I'll bog the engine down and stall. Luckily I've never stalled from that (only forgetting to clutch in at stop lights haha).
No, its not "riding" the clutch if the clutch is "fully" depressed. At this point, the clutch is disengaged. However, if you only depress the clutch lightly so its still partial engaged, then you're "riding" the clutch and that will give you a smell like burning brakes. You don't want that. Think of motorcycles. They always have their hand on the clutch lever. It's how you drive a manual. In stop and go, my feet are hovering over the brake, gas and clutch the whole time ready to mange all three while I am in stop and go or slow moving traffic. It's a dance. The only time your foot is not hovering the clutch pedal is if your cruising along. Otherwise, before a turn, in a turn, slow moving traffic your foot shoot hover the clutch pedal. You may need to engage it if conditions change or if you need to "feather" it due changes in speed under slow down or exiting a moving traffic. It's not always press clutch, shift and forget. Your always staying close to the clutch pedal in traffic.Doesn't that damage the throw out bearing for the clutch? Like if I'm in stop and go traffic (fast enough to only be stopped for a second) and need to be in first to keep moving, would that not be riding the clutch? Or is that how you're supposed to use the clutch? I had to do it it the other day while driving in light traffic, but wasn't sure if it was good practice.
You're right about the definition of riding the clutch, but he's talking about the throwout bearing, which is in between the clutch fork and the diaphragm. If you sit for minutes every day with the clutch pedal depressed waiting for a light, for instance, you are going to wear out your throwout bearing quite a bit faster. It's a dry bearing with only limited lubrication. It's a good reason to sit in neutral at the light or waiting for someone in the parking lot.No, its not "riding" the clutch if the clutch is "fully" depressed. At this point, the clutch is disengaged. However, if you only depress the clutch lightly so its still partial engaged, then you're "riding" the clutch and that will give you a smell like burning brakes. You don't want that. Think of motorcycles. They always have their hand on the clutch lever. It's how you drive a manual. In stop and go, my feet are hovering over the brake, gas and clutch the whole time ready to mange all three while I am in stop and go or slow moving traffic. It's a dance. The only time your foot is not hovering the clutch pedal is if your cruising along. Otherwise, before a turn, in a turn, slow moving traffic your foot shoot hover the clutch pedal. You may need to engage it if conditions change or if you need to "feather" it due changes in speed under slow down or exiting a moving traffic. It's not always press clutch, shift and forget. Your always staying close to the clutch pedal in traffic.
