HONDANB
JOHN DOE
FL
NEEDED
I don't have Instagram, is there a link or email/phone number you could post in order to contact them?
Nope. I was in your same position. Didn't have Instagram. Had to open an account just for this as he would only take orders through Instagram.
albi
Dallas, TX
Just create an account to buy them and then delete. He only does business through ig and is increasingly more common for people / companies
I added the following interior lighting to the FL5:
1. JDM OEM LED Tailgate Light (08E17-T43-000) - this LED light is a net new light located just below the left tailgate grab handle. This part is a complete kit that consists of wiring harnesses, LED light with switch, zip ties, template to make the cut, bezzle/housing for the light, foam inserts to prevent rattles, and other miscellaneous components. A+ quality kit with literally everything you need to install the light. I expect nothing less from Honda. What's interesting is when you remove the panel and flip it over, it's already premarked for where this light should go (see picture). In total, this takes 2-3 hours to complete properly if working at a leisurely pace.
2. JDM OEM LED Room Lamp (08E13-E4A-A00) - this LED light replaces the current halogen light located in the tailgate area on the right. This is really straight forward, you're simply swapping one light for the other. This takes less than 5 minutes to complete.
BLUF: These lights significantly enhance the lighting conditions in the tailgate area. The lights are OEM, functional, and look good. What more can you ask for? I've included photos below of parts of the installation along with before and after.
11th Gen Honda Civic What did you do to your FL5 today? IMG-20230614-WA0004
11th Gen Honda Civic What did you do to your FL5 today? IMG-20230614-WA0005
11th Gen Honda Civic What did you do to your FL5 today? IMG-20230614-WA0006
11th Gen Honda Civic What did you do to your FL5 today? IMG-20230616-WA0002
11th Gen Honda Civic What did you do to your FL5 today? IMG-20230616-WA0003
11th Gen Honda Civic What did you do to your FL5 today? 20230616_134325
Before:
11th Gen Honda Civic What did you do to your FL5 today? IMG-20230614-WA0002
After:
11th Gen Honda Civic What did you do to your FL5 today? IMG-20230614-WA0003
11th Gen Honda Civic What did you do to your FL5 today? IMG-20230616-WA0004
FYI - These items are pictured on Page 6 of the JDM Honda Genuine Accessory Catalog along with part numbers.
Is it effective at shining light into the cargo area?
Yes, it is; however, I recommend doing them both. I cannot speak to the gain if you only install one light. See my comment above starting with "BLUF". The entire cargo/tailgate area benefits from the addition of the LED lights. Ambient lighting will play a factor so keep that in mind.
MrB
UK
Your boot tray has a red "R" - that's cool. Mine is all black.
Estoril4
2018 Hatchback Sport Mt, 2017 Toyota 4runner XP, 2014 Audi S4, 2017 CBP Type R
HONDANB
JOHN DOE
FL
NEEDED
I find them pretty snug and yes they are available in black
@Clark_Kent Thanks for posting! I need to take the rear interior apart because I’m 99% sure I have a loose wiring harness which is BADLY rattling in the lift gate when I hit bumps. While I’m taking things apart, I may as well install that LED kit. It looks great!
