Hi there, I plan on lowering with springs about 1 " drop
this might be a no brainer question to some but I'd like to understand this well rather than blindly do what every one else is doing... considering both rv6 camber arms and spc adjust camber but from two different positions on the knuckle (upper and lower) is there any concern if one were to install both at the same time even if it was only to help reduce weight since they are lighter than oem
i don't fully understand why camber can be adjusted from two different positions on the knuckle (spc upper, rv6 lower)
again if one were to get both does that mean they can potentially run -6 °, 3 from spc and 3 from rv6 .... not that i would do that but just trying to understand what or how the oem was designed and what those two vendors were thinking when making two different replacement improved products for the same end goal
I did not need to and managed to get -2.0 in the rear even for camber.Have you had to use camber arms for the rear???
What???!You can't really adjust the front unless you have coilovers.
You can, its just very limited. The top hat strut holes are elongated/oval and you can move the strut in/out about .5 degrees (-ish) if you pull the top strut pins on the stock top hats.You can't really adjust the front unless you have coilovers. There are ball joints available but they don't really adjust but give a "setting" for 1 degree in the negative or 1 position in positive camber. All depends how low you go.
