fenix-silver
- Joined
- Nov 12, 2018
- Threads
- 21
- Messages
- 693
- Reaction score
- 59
- Location
- Central PA
- Vehicle(s)
- 2024 Type R; 2019 Si (sold)
crap, well I guess I need to swap the left and right side mesh pieces now. ugh
Mine went together so I may just leave it "flipped"...crap, well I guess I need to swap the left and right side mesh pieces now. ugh
I would think any adhesive remover would do the job.Would the tape ruin the paint when/if we are to remove the mud guards in the future? If so, I am inclined to not use the tape.
In cold weather, I don't think it really matters as the material becomes stiffer.Totally understand - no worries on the screwdriver. I could model one myself in about 3 minutes, but thought I would ask.
I installed mine a few days ago and didn't bother with the VHB tape yet, but I think I am happy with the positioning now. Is there any harm/risk in not using the tape?
I think I mentioned this earlier in this thread. I actually installed my own tape so that it would extend for most of the flap to prevent this. I also PPFed behind the flap beause rocks will get in there and sit there till you remove em. I knew this because happened on my old car, every once in a while I had to wiggle the mud flap and get a credit card or think plastic tool in there to remove dirt and rocks that got stuck there.I just wanted to share an observation, and I'm curious if others have noticed this...
I was showing these guards to a coworker the other day and he reached down and flexed one of the front guards backwards, and a small pile of pebbles fell out. I'm guessing that these are just collecting between the main part and the finer mesh part?
Please note that I have NOT installed the VHB tape yet, but I am still planning to do so. I spent a fair amount of time driving around in a big parking lot while I was teaching my son to drive a manual, and it was kicking up lots of little pebbles from that lot. I even had a few times where it sounded like a pebble found its way between a brake rotor and caliper or shield and started scraping. (This was easy to clear by just backing the car up for a short distance).
So my question is whether this happens if you DO apply the tape, and is there a way to purge the pebbles out somehow?
I need to inspect more closely to see how much space there is between the fine mesh insert and the coarse mesh of the main flap.
I did look at this again last night when I left work and there were accumulated pebbles in there (I checked the opposite side that was "purged" by my coworker). It did seem like there was a bit of waviness in the flap that would likely have been mitigated by having the tape in place.I think I mentioned this earlier in this thread. I actually installed my own tape so that it would extend for most of the flap to prevent this. I also PPFed behind the flap beause rocks will get in there and sit there till you remove em. I knew this because happened on my old car, every once in a while I had to wiggle the mud flap and get a credit card or think plastic tool in there to remove dirt and rocks that got stuck there.
The tape will definitely help and the longer the tape the better but I bet still gonna get some dirt and small stones in there, we will see.
PS4S are sticky compared to winters for sure but nothing like 200tw.I did look at this again last night when I left work and there were accumulated pebbles in there (I checked the opposite side that was "purged" by my coworker). It did seem like there was a bit of waviness in the flap that would likely have been mitigated by having the tape in place.
Seeing this made me wonder if it would make sense for the front-most mesh (the part that is integrated into the flap) should be finer? I'm not sure how feasible that is with the 3D printing process, though. And would it restrict airflow through the vent too much? I'm not clear if these vents in the car are meant as a brake cooling feature, or an aerodynamic feature (or both)...
EDIT: I meant to add that since swapping in the stock wheels/tires a few weeks back, I notice that the stock tires tend to kick up a LOT more pebbles and road debris than my winters did (Blizzaks). Are these stock tires really that sticky? I was glad to have these guards installed when my son and I were driving around in the previously mentioned parking lot as I listened to all the sounds of pebbles bouncing off the inside of the wheel wells.
I just used a couple screwdrivers to pry. The OEM clips don't unlock, so they will just break.Just got mine, and I'm kind of stumped on the step where you need to remove the push type plastic fasteners (front). I have the pry tools but the tool (or a flat-head screwdriver) can't get under neither of the fasteners to pull them out. Any tips here? I'm kind of stuck here. @KhaoS2K
The plastic clips break easily; however, they can be removed without breaking. A plastic clip removal tool like this one is best for a task like this. It's also a good practice to have spare clips on hand since they're cheap.Just got mine, and I'm kind of stumped on the step where you need to remove the push type plastic fasteners (front). I have the pry tools but the tool (or a flat-head screwdriver) can't get under neither of the fasteners to pull them out. Any tips here? I'm kind of stuck here. @KhaoS2K
