PointByPatrol #21985 Build Journal! RIP #9243
MooMoo
after doing this today with @PointByPatrol , I’d probably go with speed bleeders. I have them on my RX7 and it’s an easy one man job. Crack them a 1/4 turn, attach vinyl hose to a empty plastic water bottle and then just pump the brake 5-10 times, watch fluid, top off as needed, and close when done. Having to wait 5 min for the mity vac to suck the rear was slow. Also nice because you don’t need an air compressor.
yeah I just use a power bleeder (I use a motive copy) and its painless and fast (even on the back brakes).
Speedbleeders are neat, I have though about getting some stahlbus ones, expensive but superior design to speedbleeders. These brembo calipers since are aluminum seem pretty sensitive on how much torque you put on the bleeder valves so seems important to torque properly, have seen people overtorque and having the valves weep. Actually thought it happened to me but they seem fine now
Club Version
Jose
Miami
www.youtube.com
FL5 Championship White
How you liking the HEL SS lines? Do you feel a big difference in pedal feel and modulation?
Djseto
It's only been a day but they feel no different to me. The bigger test will be next month when I get on track. I've used stainless lines on all the motorcycles I used to have and track as well as on my RX7. For anything that sees the track, it's an inexpensive mod to help insure consistent brake pedal feeling when things "get serious".
svvitch
Matt
When can you share more about the radiator?
After testing. I have a track event coming up in September, so ECT's will be something high on the priority list to keep an eye on!
svvitch
Matt
Nice ok thank you for testing! I dumped in a bottle of water wetter that's basically the same thing right? ?
So for this test I'm using straight factory coolant. What I actually prefer to run in warm weather is 1 bottle of water wetter, 1 gallon of distilled water, and then I fill the remaining capacity with factory coolant.
svvitch
Matt
Factory would be ideal if it works. Who wants to drain/refill every season. Sounds like a great test!
