I understand where you’re coming from. Driving manual in rush hour stop/go traffic is never fun and can get tiring (even for younger drivers). As others have said, there are times when automatics are better. This is where a 2nd vehicle (with automatic) comes in very handy. Keep your FL5 for when you want to drive. But have an automatic handy for when you need comfort and convenience.And pressing the clutch all the way down every time makes me feel tired. Remember driving manual car 30 years ago was fun, but now getting old, sometime hesitate to drive this car, especially during rush hour.
when the fl5s first came out, someone on yt posted a review, and part of that was a clutch stopper that mounts under the clutch pedal and shaves a fraction of an inch of travel. Anyone know that product and is it "safe" for clutch operation?And pressing the clutch all the way down every time makes me feel tired. Remember driving manual car 30 years ago was fun, but now getting old, sometime hesitate to drive this car, especially during rush hour.
That sounds like a terrible idea. What if your clutch was out of adjustment and you needed that last bit of travel to fully disengage it? You're handicapping your ability to use the full travel of the clutch. You're not improving or changing the actual clutch in the drivetrain and how it works, you're just making it impossible to use the last bit of travel when you need it.when the fl5s first came out, someone on yt posted a review, and part of that was a clutch stopper that mounts under the clutch pedal and shaves a fraction of an inch of travel. Anyone know that product and is it "safe" for clutch operation?
per JSR Engines it is "safer"when the fl5s first came out, someone on yt posted a review, and part of that was a clutch stopper that mounts under the clutch pedal and shaves a fraction of an inch of travel. Anyone know that product and is it "safe" for clutch operation?
I had to when the clutch pedal bracket broke in my 07 FA5 Si…Technically you can shift without pressing the clutch at all but i wouldnt recommend it..
Just wanted to say thanks for this info. I have felt this “overstroke” in the shift knob while going from 1st to 2nd since I got this car and haven’t been able to figure out why. It feels like the clutch isn‘t fully disengaging and for a split second, there’s a feeling of resistance trying to move the shifter out of 1st gear. I had tried adjusting the free play and clutch fluid flush without any resolution. To test out this process, i added some leftover 3m clear rubber in place and it solved my issue. If i slammed the clutch pedal all the way down, squishing the rubber, I could reproduce the symptom. If I depressed the clutch without squishing the rubber down, the shift was smooth as it should be. Ill be ordering the disc mentioned above to make this more permanent.per JSR Engines it is "safer"
This JSR pedal stop kit allows a certain amount of stroke on the diaphragm while avoiding over-engagement or gear lock out on high rpm shifts. Anyone that has driven a stick shift car knows when you power shift or shift fast you should always half pedal to allow for smoother seamless shifts. When you slam the pedal to the floor it over extends the diaphragm of the clutch system almost making it seem like you are not pressing the clutch in (reversing the process). The reason for this is the clutch is designed and operates on a certain amount of stroke or allowed throw. When you pass that threshold the pressure plate begins to close as if its not being activated. This kit will limit your clutch slave throw allowing super quick and effortless shifts.
https://www.jsrengines.com/product/jsr-fl5-de5-clutch-pedal-stop-kit
Blackhawk makes same/similar stopper:
Preventing poor disengagement due to clutch overstroke and This is a clutch pedal stopper for adjusting clutch stroke. The seat position will also be improved by installing it.
https://www.blackhawkjapan.com/collections/body-reinforcement/products/rigid-aa1020-2
Being a cheapskate, I could not get myself to pay $54 (w/shipping) for the clutch pedal stopper, so I got this from Amazon for $0.80 per disc:
https://www.amazon.com/PATIKIL-Rubber-Washers-Anti-Vibration-Bushings/dp/B0F248XGZ4/
and used 3M double sided tape, which I already had at home, to mount it onto the OEM clutch pedal stopper:
https://www.amazon.com/3M-Scotch-5952-VHB-Tape/dp/B01BU7038A/
I don't have a picture, but the combo measured 8mm which is just about 5/16"
the rubber disc is not hard/rigid, which I like over the hard OEM hard plastic stopper
I also adjusted the clutch pedal to eliminate most of the free play at the top
next step will be CDV delete, but need to get a bleeder kit first...
FYI, there are other "disc" you can get. I cannot find the post, but one person used a furniture slider which is made of harder plastic, and makes a "click" sound when you hit it with the pedal. he liked it. I wanted to keep mine quieter, and opted for the softer rubber.Just wanted to say thanks for this info. I have felt this “overstroke” in the shift knob while going from 1st to 2nd since I got this car and haven’t been able to figure out why. It feels like the clutch isn‘t fully disengaging and for a split second, there’s a feeling of resistance trying to move the shifter out of 1st gear. I had tried adjusting the free play and clutch fluid flush without any resolution. To test out this process, i added some leftover 3m clear rubber in place and it solved my issue. If i slammed the clutch pedal all the way down, squishing the rubber, I could reproduce the symptom. If I depressed the clutch without squishing the rubber down, the shift was smooth as it should be. Ill be ordering the disc mentioned above to make this more permanent.
