OEM Honda MTF. I use it in all of my Honda cars... street and race cars.What grade oil would you recommend?
I suspect the latter has been my issue.I beat the ever living shit out of my FL5 and it doesn't grind any gear. Let is warm up before romping on it and its fine. If you are grinding gears you aren't shifting right.
I notice the same thingI've noticed that the 2nd gear shift at lower speeds is a bit crunchy at times.
Do you guys think this is user error on my part or an issue I should take to the dealership?
What type of perfect shifting should be done? Ive driven multiple stick shift cars including the 10th gen Si and FK8 and damn the FL5 is horrible. I have done everything and 2,3,&4, just dont stop grinding every time i get into gear.I beat the ever living shit out of my FL5 and it doesn't grind any gear. Let is warm up before romping on it and its fine. If you are grinding gears you aren't shifting right.
Me too. "Crunchy" is the perfect way to describe it. Not a grinding for me, more like the notch to get in second is not smooth as all of the others. I get that feeling whether im casually driving or redlining it. It's not every shift to 2nd either, some feel really smooth. Every other gear, except reverse, is like butter every time.I notice the same thing
I feel the same way in my car and might just confuse it with grinding. But yeah i might not keep this car. Its just not enjoyable to drive. The FK8 didn’t feel like this at all.Me too. "Crunchy" is the perfect way to describe it. Not a grinding for me, more like the notch to get in second is not smooth as all of the others. I get that feeling whether im casually driving or redlining it. It's not every shift to 2nd either, some feel really smooth. Every other gear, except reverse, is like butter every time.
I ran Amsoil in my Si and found that it was better than OEM in all possible ways and situations, including extreme cold weather (-20’s and -30’s). I had been running Honda MTF for 3-4 years before I discovered Amsoil. The effect is definitely not imagined nor a placebo. The stuff WORKS.Amsoil in my Si shifted great when it was above 70 outside but in the cold was worse then OEM Honda fluid.
