It's possible that is a 2021 model. As far as I am aware, 2022+ Hondas aren't vulnerable to these attacks. Also, every relay attack I've seen on camera has been the thieves walk up to the front door with signal amplifiers and try to capture the RF from the fob somewhere near the door. These thieves in this video just went straight to the car.
They will find a way...
I'm planning on adding another switch to the clutch pedal that needs to be pressed too in order to start the engine
This is a CANbus injection attack. Adversaries would buy a device sold on the dark net disguised as a JBL speaker, break into the wiring of your headlights which is one node of communication on the bus with your ECU. Once you’ve opened your doors and started your car, the bad actors can then use this device to mimic your keyfob, walk up to your car, unlock the doors and start ignition to drive away.It's possible that is a 2021 model. As far as I am aware, 2022+ Hondas aren't vulnerable to these attacks. Also, every relay attack I've seen on camera has been the thieves walk up to the front door with signal amplifiers and try to capture the RF from the fob somewhere near the door. These thieves in this video just went straight to the car.
Where would you go? There is a nice convenient USB device for the FK8 but the company that makes them hasn't done it for the FL5 yet. I like to get a killswitch device installed too but not familiar with how to go about getting one installed
A push button that interrupts the clutch pedal switch.Where would you go? There is a nice convenient USB device for the FK8 but the company that makes them hasn't done it for the FL5 yet. I like to get a killswitch device installed too but not familiar with how to go about getting one installed
Good starting point for sure. I would remove the speaker from the AirTag though if you decide to go that route.it sucks to pull out the key from the punch and putting it back in but it beats getting the type R stolen!
Thought about a steering wheel lock but it look so early 90s
i like the idea of a kill switch but don’t want someone to mess with the wiring.
so a pouch and an hidden AirTag will do for now
