FL5R-05967
I'm on 275/35 R19 on 19x9.5 +43. I think anything beyond that may rub, +35 would need much more camber I'd think to not rub..
I am considering the same and based on previous posts it seems that 275/35R19 should fit just fine on OEM tires and unmodified suspension setup.really debating or not to get 275’s also once my tires are worn out. almost there. I want to stay with 19’s and no springs or spacers, so i’m kinda hoping with the 35 side wall it will be a touch better ride and also being a 275 will help space it out a bit. does this mess with the speedometer or anything changing tire size?
i wonder if there are any 275/30/19’s out there they make?
I am also curious about tire pressure, if I move to 275/35R19 and for daily street/highway driving, should I keep the pressure the same? higher? lower?I am considering the same and based on previous posts it seems that 275/35R19 should fit just fine on OEM tires and unmodified suspension setup.
you mentioned speedometer reading, which I do not care much about, as I always drive as fast as I can![]()
but I am curious about something else, the larger tires changes the overall gear ratio, essentially making each gear a bit taller, my guess is that it will make acceleration slower by about 5.22% (same as the circumference difference)
I just got a set of 275/35/r19 Continental Extreme Contact Sport 2 mounted last week. I think the extra width helps for the Contis that seem to have a lower "shoulder" than the Michelins. Absolutely no regrets and no rubbing (stock suspension). I was a devout Michelin fan for two decades but this will now be my third set of Contis (Extreme Contact DWS 6+ mounted to a second set of rims for the Type R and for full time use on my Accord) and I have to say I am a convert.
how has that size held up? I’ve been thinking about switching to that exact size.![]()
So far so good - but we are talking very small sample size (maybe 500 miles before I had to put on the all-seasons). Never had any rubbing and the ride was better. Probably has to be some drop in performance, but on the street, I did not notice much of a difference. I suspect you might on a track when pushing the car to its limits.how has that size held up? I’ve been thinking about switching to that exact size.
I plan on daily driving the vehicle and using it in the winter time here the lowest it gets is about 25° don’t see myself tracking the car for some time so I think the set up will work wellSo far so good - but we are talking very small sample size (maybe 500 miles before I had to put on the all-seasons). Never had any rubbing and the ride was better. Probably has to be some drop in performance, but on the street, I did not notice much of a difference. I suspect you might on a track when pushing the car to its limits.
