Accord end links upgrade for 11th gen civic
keebytie9
Keeb
2023 civic si
Hey guys. In the last gen civic some people swapped the civic end links for accord ones. Was wondering if anyone knows if the any of the accord end links are compatible with this new generation of civic? I know the sway bar from the 10th gen civic is the same as 11th gen. Is it safe to assume then that the end links are the same?
efraziersc
Evan
South Carolina
2023 Honda Civic Si
Do you guys happen to know the part number for the Accord end links that work with the Si? Thanks!
Chilly613
Southern California
2025 FL5 Civic Type R
absolude
GTA
KW SC 2007 CSX Type S, 2023 PWP Si
Chilly613
Southern California
What torque specs did you use for the 10th gen type r sway bar and accord endlinks?
These are the torque specs I used, they're from the 10th Gen Civic manual, but should be about the same for the 11th Gen.
11th Gen Honda Civic Accord end links upgrade for 11th gen civic 1714415090165-em
ehsan
Bartlett, IL
Si
curious where anyone who has torqued that nut on the end link got their open ended torque wrench
Dan_E26
Dan
Columbus, Ohio
2023 Civic Si (Sonic Grey Pearl)
I fit an FK8 swaybar and end-links into my 2023 SI. You should have no issues using the Accord links, but definitely consider doing the swaybar too, no real point otherwise
