jakdotdot
Cali
2018 SI
If it isn’t your standard testing procedure then you should not put it out or you should be clear about the conditions. I’m not shilling for Honda or the 11th, but I work in publishing and I think that is irresponsible editing.
Do we actually know they did that? Or are you just guessing?
MT actually has testing/correction standards.Unlike other people/publications.
I have a funny feeling if MT posted more favorable times, you wouldn’t be complaining.
to be clear, I have no doubt poor prep would hurt ET and 60, but it wouldn’t hurt the trap speed nearly as much. Especially if they are correcting for weather conditions as MT does.
OGGsr
Jamie
Richmond VA
PWP 2022 Civic Si
I saw on another website that the two Civic Si's campaigned at the 24 hours of Thunderhill by Honda both blew their engines using a previous generation tune. Does anyone know the cause(s)?
KIKUTWO
Steve
FL
16 Golf R
Are they trying to say 220 wheel? Yeah I’ll wait for some other dyno sheets before I believe Honda underrated the car by 40 crank horsepower. That would be a real stroke of marketing genius. The Hondata dyno is known to be … um, generous and Doug is a hype man.
Why would Hondata overstate baseline when it would make their gains that much harder to obtain and sell?
OGGsr
Jamie
Richmond VA
PWP 2022 Civic Si
Maybe to inflate the overall higher numbers? My butt dyno doesn't jive with the ~225 horsepower claim from some of the dyno-tested cars we are seeing online.
TypeSiR
Car Driver
On a Twisty Road
1.5T Civic, CTR, MX-5, Fit
Crank hp vs wheel hp. Know the difference.
jakdotdot
Cali
2018 SI
Hondata’s dyno doesn’t measure crank HP. It just reads really, but consistently, high.
Minus 12-ish percent for a more typical dyno jet number.
Kullervo
Cincinnati
2011 Civic Si
They apply a correction factor to approximate crank horsepower.
Yes, it ends up about 10% higher than a roller dyno, but they’re literally measuring different things.
