eromani
- Aug 9, 2023
- 1
- 20
- 16
- Twin Cities, MN
- 2023 Civic SI, 2021 Mustang Ecoboost
- #16
Glad you're getting to autocross the car!This thread is relevant to my interests!
Just picked up my 23 Si back in May and have run it in my first autocross events ever over the summer - the second was just this past Saturday at Summit Point in WV.
My performance on Saturday was, to say the least, disappointing. Last in street class, over 12 seconds slower than the fastest car (a heavily modded ND Miata)...and most embarrassing was the 2005 Toyota Corolla that finished two places above me ? ?. To be fair, he at least had performance wheels and tires on the car, and some kind of free flowing exhaust...but still, getting beat by an almost 10 year old Corolla is pretty humiliating.
I'm still bone stock, including riding on the standard Goodyear all-seasons. Needless to say, the car is awful when it's sliding / under-steering around every corner. I also realize that as the driver, I have A LOT to learn about the sport, driving technique, etc. (My 21 y/o son, who autocrosses a slightly modified NB Miata, told me that the "driver mod" is the most important!)
But I also know that if I want any chance to stop finishing close to dead last, I need to make some changes. Here is what I'm thinking:
Ultimately I need to decide if dropping around $3500 on the above mods is worth it. I'd hate to spend all that only to find out that my skills on the autocross track are just not going to improve enough to take full advantage of the upgrades.
- lightweight wheels and summer performance tires (looking at Konig Dekagram 18 x 8.5 wheels; not sure about tires yet, but slightly wider 245/40 w/ ~300 tread wear as I want to get a couple years out of them if possible - open to suggestions?)
- rear sway bar (thinking about SiriMoto 20mm)
- rear motor mount (but I think this will push me out of Street Class into STH so may not want to do this)
- high volume air intake (PRL)
- exhaust (looking at the MAP catback "street" version)
Going to follow this thread and excited to learn more about autocrossing the Si.
Here is my perspective on a few things...
1. (Fact, not perspective) To stay in street class, you have to stick with the same wheel width, and within 1" of OE wheel diameter. So you can do 17x8 and put 245 or 255 tires on. 300tw is a pretty good place to start.
2. I would try to stay in GS for a while until you are driving beyond the capabilities of your car and need more. So I wouldn't do the motor mount yet. Order of importance for autocross is tires, wheels, suspension (springs/shocks, anti-roll bars, alignment), then bushings/bracing etc. and I wouldn't touch those until you have a SOLID understanding of what and why to change, both as a driver and on the engineering side.
3. I ran my SI bone stock on all seasons for a practice event and noticed a few things. A lot of corner entry understeer, but very correctable with trail braking. Mid corner, balance is great. Able to rotate the car with throttle adjustments, no understeer. Corner exit understeer, but that's both expected from FWD and a good thing (makes it easier to drive faster). The good thing about the stock all season tires is you can drive at the limit at slower speeds and gives your brain plenty of space to analyze the car's behavior and how to adjust driver inputs. In other words, if you need to work on your driving, it's easier to do so on all-seasons.
4. If you want to go to STH eventually, then you basically need 200tw tires, a way to get 2 deg or more of negative front camber, stiffer front springs, then stiffer rear sway bar. The easiest way, but not cheapest, is coilovers with camber plates. This would make your car relatively competitive locally, but IMO the civic SI is very competitive in GS, less so in STH.
5. If you don't care about being competitive and just want to build yourself a better handling car, then by all means go to STH and have fun.
Others feel free to chime in and disagree.
