πŸš€ tezzasaurusrex - Time Attack FL5 Build Journal
hhkb
civic
A note on the Spoon spring spacers, I've now installed several sets of new release Spoon springs (now have thicker and higher quality black spring insulator on them) and have discovered they no longer sit low in the rear.
So for anyone who have the new release springs, you do not need the spacer I developed to raise the rear end.
If you have any questions feel free to respond here or send me a PM.
Thanks all
Thanks for the update! I was eyeing the Spoon springs.
tezzasaurusrex
tezzasaurusrex
Terence
Australia
Paragon rotors and Project Mu HC-CS pads fitted in prep for upcoming track day.
Initial impressions on street; lots of bite straight off the bat, hardly needed to bed the pads in to feel the bite. Seems I'm getting into ABS threshold with less pedal pressure. Will see how they behave on track. Got Elig Titanium shims behind the pads as well.
11th Gen Honda Civic πŸš€ tezzasaurusrex - Time Attack FL5 Build Journal 2024-03-31__00.16.28
11th Gen Honda Civic πŸš€ tezzasaurusrex - Time Attack FL5 Build Journal 20240406_184952
11th Gen Honda Civic πŸš€ tezzasaurusrex - Time Attack FL5 Build Journal 20240406_165246
Car is looking good!!
garettb16
Garett
Australia
Loving your setup mate. And if I wasn’t in Melbourne I’d be coming to see you about my setup.
What are the specs on your new CE28s?
tezzasaurusrex
tezzasaurusrex
Terence
Australia
tezzasaurusrex
tezzasaurusrex
Terence
Australia
PB posted. But not entirely satisfied with the pace, track did feel a bit slow and greasy but the car felt great in terms of handling balance. The Tein coilovers are superb...
11th Gen Honda Civic πŸš€ tezzasaurusrex - Time Attack FL5 Build Journal FB_IMG_1713395726351
tezzasaurusrex
tezzasaurusrex
Terence
Australia
Are you still at factory ride height? Did you have to roll the fenders?
-25mm from factory
No fender work needed with enough camber and the right kind of camber
Geraldfl5
Gerald
Pittsburgh
2023 type r 2003 Vw Passat wagon
Changed over to a HC20 (Odyssey PC680 equivalent) battery. Saved 9kg ~ 20lbs
Oh and 18x10 SAGA with 275/35R18 RE71RS fitted ready for track
[/QUOTE
what battery hold down are u using
Car00071
St. Louis, MO
2024 Integra Type S
-25mm from factory
How much camber front and rear? Which one was the issue?
tezzasaurusrex
tezzasaurusrex
Terence
Australia
Aeroflow but I had to modify the top brace quite significantly to make it work. There are better solutions out there where the brace goes long the width of the battery rather than down the length.
11th Gen Honda Civic πŸš€ tezzasaurusrex - Time Attack FL5 Build Journal images (58)
11th Gen Honda Civic πŸš€ tezzasaurusrex - Time Attack FL5 Build Journal 20240410_212919
