TheFactor
Did you YouTube a how to video ? Just ordered a PRL intake and debating if I want to do it myself or not .No Eventuri this time around?
Happy 4th BTW ????
I don't think I did one for the intake, but it's super easy!Did you YouTube a how to video ? Just ordered a PRL intake and debating if I want to do it myself or not .
Happy 4th BTW ????
Yeah I just looked and didn’t see one .Maybe super easy for you ?I don't think I did one for the intake, but it's super easy!
It's doable. I just did it yesterday myself. Took a few hours since I was taking my time. BTW, if you look on youtube you'll see one walkthrough that involves taking out the actual CPU from it's container and the instructions from PRL also suggests that which is not needed. You just take the bolts out that holds the holder and you can lift it out of the way to mount the snorkel.Yeah I just looked and didn’t see one .Maybe super easy for you ?
Watched your drive after the install with your mods and sounds incredible!
The sound after is fantastic.
Me 3I didn't pull the computer either. Just lifted it up!
Thanks for the reply and help ??It's doable. I just did it yesterday myself. Took a few hours since I was taking my time. BTW, if you look on youtube you'll see one walkthrough that involves taking out the actual CPU from it's container and the instructions from PRL also suggests that which is not needed. You just take the bolts out that holds the holder and you can lift it out of the way to mount the snorkel.
And hopefully me 4 ? when it arrivesMe 3
I’m actually considering not running the extra air snorkel and either capping it off or letting the open area draw extra air it should be off to the side and low enough I think to still draw cooler air when the car is moving like the snorkel would .Reason being the ease of the install and if and when I need to swap it back to stock it’ll be much easier. After all PRL is the only one running that snorkel and the other manufacturers do fine without it . I think it’s a great idea but for my application it might not be worth the dog in the fight . I’m not chasing numbers or extra power and any would be a plus but I am looking forward to the extra whoosh whoosh noises ?
Thanks for the confidence lolI am an idiot and was able to install it the snorkel isn't hard to do.
I've got it on the side of my air box to deflect heat. I also wrapped the large water bypass pipe behind the turbo!Yo man! Saw you on Gears and Gasoline. Also noticed you had a good bit of shiny gold tape in the engine bay. What parts did you cover with it? I have some sitting on my shelf and might as well use it.
Oh yes! That was on the first or second lap, and he entered the esses at 135! PTSD set in big time!I watched G&G and your on-board video this weekend with my other half. I have to admit, I got a good chuckle when you gripped the arm rest.
Thanks for repping, as always.
