Thats what i thought but someone online mentioned it would work its just that hondata dosent have any can maps for it. Also they said canbus just gets you carb compliant. ?PRL kit will not work with the FL5,DE5 platform sadly and Hondata’s solution will probably be the only one for now if it ever comes out.
Hondata could adapt the canbus system to other kits. But from a business standpoint it makes no sense.Thats what i thought but someone online mentioned it would work its just that hondata dosent have any can maps for it. Also they said canbus just gets you carb compliant. ?
Also it does seem like an option under new calibration, 91 octane hondata fuel system flexfuel enabled.
When i said can i mean base maps arent provided but it has thr capability of working.Hondata could adapt the canbus system to other kits. But from a business standpoint it makes no sense.
If I can sell you something that you need and nobody else has a solution what is my incentive to lose money to other kits?
They could make just a canbus system adapter to current offerings but you are leaving money on the table.
Important Notes:When i said can i mean base maps arent provided but it has thr capability of working.
https://prlmotorsports.com/products...5-wifi-ethanol-content-analyzer-flex-fuel-kit
It has the capability but only for the unreleased hondata kit sadly.When i said can i mean base maps arent provided but it has thr capability of working.
I am glad that you are enjoying the car! Also I appreciate your kind words. Looking forward to what is next.Jester is the ?!! My mind is absolutely blown and expectations far exceeded. For a while there I was worried this car was just "slow" and Jester changed my mind. The car PULLS now in every gear and the car is smoother overall. Not only is the car"faster" now, but Jester's level of service is unmatched. He is responsive, polite, friendly, and an overall great person to do business with! Not only does he make your car run right, but he is extremely knowledgeable too! He takes the time to explain things if you don't understand and has hands on expierence with modding these cars. Can't recommend him highly enough.
If you are in the market to tune your car and looking for a tuner who knows this car inside and out, look no further! Jester Tuned is the answer.
Thank you again and look forward to working with you in the near future as I continue modding,
What are the mods on your setup?![]()
Finally, got my pro tune done here in kansas city on 93 pump gas. It's a little more smooth with more power than hondata's ots tune. Modified by KC did my tune on the conservative side for longevity and not lean out the cylinders which is why it's not pushing over 430hp that it probably could. I'll wait until hondata comes out with the can-bus flex fuel kit to get that reliable power.
Hvi prl intake with upgrade intake pipes, 27 won kuro turbo and high flow cat. converter, prl intercooler and charge pipes, hondata upgrade lpfp, hpfp, 1330cc injectorsWhat are the mods on your setup?
Oh yeah then absolutely you have room to go. I tuned a similar setup on @PointByPatrol car.Hvi prl intake with upgrade intake pipes, 27 won kuro turbo and high flow cat. converter, prl intercooler and charge pipes, hondata upgrade lpfp, hpfp, 1330cc injectors
