Help needed (Info on LED headlights)
turbotan
Singapore
Honda Civic
Hello everyone, as some of you know, the 11th gen civic in select markets come with halogen projector headlights instead of the standard LED headlights you guys are getting in the US. I am currently exploring getting the original headlights from my local Honda stockist and have written to the authorities on the change, however, I do require some information to submit for approval and was wondering if any of you guys can share them if you have.
1) part numbers of both left and right LED headlight units
2) technical specifications of the headlights (light brightness, angle, etc)
3) installation diagrams showing the various parts
4) safety standards certification from the US
any help is appreciated, although i know i am facing an impossible task.
Chilly613
Southern California
2025 FL5 Civic Type R
Mikstore sells the OEM LED headlights as a set. Will be cheaper than getting them from Honda. They also sell the CANBUS harness going from halogen to LED so there are no error codes.
Civic 22-24 OEM LED Headlight Assembly
chopsuey34
2025 Civic Si
Hmm, a little pricey, but this is something I might do in the future. Thanks for the tip, Chilly.
Edit: Oh my bad, US gets LED headlights, nevermind.
Chilly613
Southern California
Its expensive, but not as expensive as a single headlight direct from Honda, they're over $1K each.
Shrapnel
Justin
Los Angeles
CW 2024 Civic Type R #16838
Interesting that Mikstore has an option for used '22-'24 clear lens LED headlights for $590($1574 new/retail). That's a damn good deal if those are the actual clear LED headlights and are compatible with the FL5. Would be nice if they'd list part numbers so we could figure out what they are and what region/beam pattern they are etc.
Chilly613
Southern California
Interesting that Mikstore has an option for used '22-'24 clear lens LED headlights for $590($1574 new/retail). That's a damn good deal if those are the actual clear LED headlights and are compatible the FL5. Would be nice if they'd list part numbers so we could figure out what they are and what region/beam pattern they are etc.
Yeah, I wish they had the part number for all the OEM parts they sell.
