Check rear seat light and chime when shutting off car ?
TheFactor
Factor
So Cal
Anyone else get this light on the dash and chime every time you shut off your FL5 ? That is the only complaint I have with this car and that says a lot. Needless to say it is annoying as it does it probably 50% of the time . Even when there is Nothing on the rear seat and also I opened and closed the fold down seats rearranged things in the cargo area and cargo net.
Just curious if anyone else is having this issue with any resolution ?
Thanks in advance
Chilly613
Southern California
2025 FL5 Civic Type R
I have the warning, but its hasn't bothered me. The notification only comes on if you opened the rear doors within a certain amount of time of turning on the car. You can disable it in the infotainment system.
FL5HondaGuy
Boston
2024 Championship White FL5
Only get reminder if I put something in the back.
TheFactor
TheFactor
Factor
So Cal
Thanks guys much appreciated !
I guess knowing something isn’t wrong with the system it won’t bother me as much lol.
Although I’ll probably look in to turning it off.
@Chilly613 That explains why it only does it sometimes like you mentioned when I’ve opened the rear doors ??
frenzal
Dan
2024 Integra Type S, 2025 TLX type S, 2004 S2000
On the ITS, you can disable it in the options of the infotainment.
Bandit_TypeR
Miami
Civic Type R
Thanks in advance
FYI - You can disable the feature. It pings if you had opened the rear door then went for a ride. The car reminds you to check the backseat since it logged that you had opened the rear door before the trip. But, you can disable under the settings menu. I turned it off.
TheFactor
TheFactor
Factor
So Cal
Thank you !
