MSUGeoman
Good call there too, haven’t had any issues yet with them coming out but with the grit that gets in there I could see that being an issue long term for sureWhen you do replace the bolts, put some antiseize on them.
Right, I was gonna say. You need that chonky #3 philips head. I messed up a few of them on my first oil change before I went and got the correct tool, can't believe they use those under there.These screws are very easy to strip if you don't use the correct size phillips head. Fortunately they are also very cheap at the parts store. 90105-TBA-A00
helps if you use an electric drill to break them free. I kept rounding them out using a hand held screwdriver. i greased them last oil change and they were still a pain in the ass to break free without using the electric drill.These screws are very easy to strip if you don't use the correct size phillips head. Fortunately they are also very cheap at the parts store. 90105-TBA-A00
