This is completely normal. Give it up to 2 weeks to fully adhere to the glass. The heat will evaporate the excess water. After 2 weeks is the final, “cured” film. If your tint has been on longer than 2 weeks, then that is the final look. Taking it off and re-applying the film will not achieve a “better” look.My question is, how is the tint on the defroster lines? Mine look messed up and does not look uniform so I'll need to take it back it to have them fix it or take it out and put new tint.
Good to know. Its only been about 5 days since its been done. The shop I went to uses Solar Gard Tint. I've gotten cars tinted at this shop periodically over the years and its the tint they've used probably over the last 20 years. Yeah, its only noticeable when you're up close, from a distance you cant see it. Its been awhile since the last time I got tint done. Hopefully it does resolve itself after some more time, but at least it comes with a lifetime warranty if it doesn't.This is completely normal. Give it up to 2 weeks to fully adhere to the glass. The heat will evaporate the excess water. After 2 weeks is the final, “cured” film. If your tint has been on longer than 2 weeks, then that is the final look. Taking it off and re-applying the film will not achieve a “better” look.
Keep in mind:
This is a thin film; it’s thinner than a sheet of loose leaf paper. Any imperfection (in this case, defrost lines or dot matrix) on a flat surface (glass) will show a little bit. Not sure what film you went with, but 3M/Xpel/Avery’s Warranty standard is to stand 6-10 feet back and look at the vehicle. If it’s very visible at that point, then that would be warrantied. Also, the darker the film you have installed, the more visible said imperfections will be. So, if you have 20% on there now, then removed and re-tinted it with 5%, the imperfections would be more noticeable, and vice versa.
Hope it goes well. Here is a copy of the warranty if you don’t already have it!Good to know. Its only been about 5 days since its been done. The shop I went to uses Solar Gard Tint. I've gotten cars tinted at this shop periodically over the years and its the tint they've used probably over the last 20 years. Yeah, its only noticeable when you're up close, from a distance you cant see it. Its been awhile since the last time I got tint done. Hopefully it does resolve itself after some more time, but at least it comes with a lifetime warranty if it doesn't.
