God Spec info 18x10 +40 (pictures, alignment specs, tire info)
Nothing
2023 CW FL5 #5044
hmmm....interesting. After seeing these pics, and watching a video about spacers the other day, I think I might make a 'staggered' wheel set!! The fronts stick out more than the rear in these photos. So going to do a different offset on the back wheels to line them up better WITHOUT spacers! WOOO HOOO!!
Thanks guys!
Are you not going to rotate your tires front and back?
TypeRbuilder
Vince
Cleveland
www.tdpracingind.com
25 Civic Type R
Actually....probably have to use a small spacer in the rear....different wheel sizes won't work on a FWD car lol....well, they will, but not for rotating. And once it's not a 50/50 weight balance? I'll have to manually fix the rear offset.
Rambler
FL5 Type R
what happened to the video about the spacers? Lol The “god spec” sits pretty flush with the appropriate camber adjustments. If not, you can always go with the more conservative 18x9.5 +45 all around.
ctechauto
FL5, FK8, EK9, 981, Gen 3 Raptor
Thanks guys!
Unless you're doing reverse stagger for track purposes, this isnt an optimal idea especially for street cars. You cant rotate them front to back and if you have directional tires not even side to side unless you flip the tires.
Easy solution (both for track and street), adjust fitment with camber. -2.5⁰ minimum up front, -1.5⁰ to -2⁰ rear will even them out. The front track is approx 5-8mm wider than rear track. You're supposed to run more camber up front than rear for optimal turn-in response and tire wear (especially on track) anyway.
MERAKIAUTOWORKS
Joshua
Fullerton, CA
2022 Civic Type R
We have TE37 Saga S+ 18x10+40 in mag blue, dash white, and shining black metallic!
-Josh
gotham
Chad
West Virginia
2025 CW Type R
Just got my setup installed last night. Pretty happy with it so far. Currently waiting on my center caps to be delivered.
18x10 +40
275/35 PSAS4
H&R Springs
Camber pins pulled
11th Gen Honda Civic God Spec info 18x10 +40 (pictures, alignment specs, tire info) IMG_1870
11th Gen Honda Civic God Spec info 18x10 +40 (pictures, alignment specs, tire info) IMG_1868
11th Gen Honda Civic God Spec info 18x10 +40 (pictures, alignment specs, tire info) IMG_1872
