urbo73
2023 Honda Civic Type R
The Spoon guy was saying that their springs make for a more compliant ride compared to OEM springs. Is this true from your experience?
CTR
WA
strixauto.com
2023 Civic Type R, 2020 GX460
I’ve already ordered Spoon springs but I’m hoping for the same. I’ve become accustomed to Sport mode and if the car is even more compliant with these springs and 18” wheels I think it will be perfect overall.
NarsBaller
NarsBaller
Japs
Australia
Civic Type R FK8
I'm always iffy about using lowering springs, some of them state its only a 1 inch drop and then it turns into 1.5. How is it since everything settled? Did it drop more or stay about the same since install?
what you see in the photos is pretty much the drop of the springs which already settled. I wish it can go just a bit more lower.
NarsBaller
NarsBaller
Japs
Australia
Civic Type R FK8
Absolutely. Much improvement from stock. But again I wish it could have been a bit more lowered.
urbo73
Thanks. If they play nicely with OEM dampers and modes, then I'm ready to pull the trigger. I see no downsides.
urbo73
That looks sweet. My only concern is that I'm running the OEM wheels but with 265/35R19 tires, so the overall diameter is 1" larger than the OEM wheels and 265/30R19 tires. Since I got it like this from the dealer (I asked for the larger tires on delivery), not sure if it's "lowered" a bit already or not, and how springs would affect that, and if I might have to go to 18s with 265/35R18.
My diameter would be equal to a 265/40R18. I know those work with stock springs.
NarsBaller
NarsBaller
Japs
Australia
Civic Type R FK8
I think the 265/35/19 will work even its lowered as it does not drop the car that much.
Im currently running 265/35/18 on those sagas.
urbo73
Spoon says it lowers it by 20mm front and rear. My ride height is now higher by 1/2" or 12.5mm, due to 1" larger diameter wheel because of the taller tires. This also means the wheel gap is 1/2" or 12.5mm lower as well. So effectively, the new drop would be 20mm + 12.5mm = 32.5mm.
NarsBaller
NarsBaller
Japs
Australia
Civic Type R FK8
If you are just going to lower the car and DON'T USE any wheel spacers, you will be fine as there is a plenty of wheel clearance on the FL5, however if you will run spacers, you might rub.
urbo73
Yeah, might just have to try and see. Basically imagine your car with an additional 12.5mm or 1/2" drop.
jdOTFL5
Los Angeles
FL5 CTR #0995 CBP
did you think about going 20mm on spacers? or why did you choose 15mm? deciding on spacers now and i'm kind of leaning on 20mm with spoon springs.
