Cooling
FL5Luis
Luis
Pennsylvania
2025 Honda Civic Type R
Can someone point me in the right direction for cooling and to help the heat soaking
I added 1/4" spacers (hardware store bronze bushings - in AZ no worries about dissimilar corrosion) between the hood vent and its drip shield, using longer bolts.
I installed the WOT Cooling Plate, exchanging the supplied Allen head fasteners for 6mm x 20 flange head bolts. The Allen heads were fiddly compared to flanged, hex head bolts in my opinion.
I covered the airbox with Thermotech fiberglass backed, self adhesive foil.
IAT's generally lower than before. Zero downsides other than time & money spent.
FL5CW
North America
Did the spacers allow for more heat to exit the hood vent? Curious about this...
AspecR
Stefan
Get an intercooler, Cooling plate and upgraded radiator . If those don't alleviate your concenrs then an oil cooler and turbo cooler should get the job done.
blueroadster
MD
Please elaborate on the observations, conditions, expectations and areas of cooling intent.
zumbooruk
Ventura CA
I am curious... but could use more details please:
Did you put the spacers only on the two front bolts? or all around?
will these 8mm aluminum spacers work (slightly longer than 1/4" but Prime Day discount...)
https://www.amazon.com/PATIKIL-Aluminum-Spacers-Thickness-Standoff/dp/B0CBJJ2HR2
is this the Thermo-Tec heat shield you used?
https://www.amazon.com/Thermo-Tec-Adhesive-Backed-Aluminized-Barrier/dp/B0844NGHS6
Thanks
Spacers increase the flow area. I put spacers under all the fasteners. My car is garaged and rarely sees rain (Arizona), but it does get hand washed once dusty enough. I still want the rain shield to direct water around the O2 sensor.
BTW, RainX spot free cash wash liquid works great for those of us with hard water. Virtually no water spotting, even washed under a hot sun.
