skywardatlas
- #1
Hey everyone,
My 2022 Si, which I took delivery of in May of 2022, is the first manual I've owned. Since then, I believe I've gotten fairly adept at driving a manual and I love every aspect of this car.
There's one issue that's been present since the beginning though and as this is my first manual car, I wanted to see if this was a relatively normal issue with manual transmissions. In first gear, after I've already set off and the clutch is fully engaged (clutch pedal up), the car is extremely jerky around 5-7 MPH. It doesn't matter if I'm coasting (gas pedal fully lifted up) or if I'm applying very slight throttle to keep the car at a consistent 5 or 6 MPH; the car will pretty violently jerk back and forth. Disengaging the clutch obviously smooths the car out. Accelerating normally from a stop up the gears doesn't result in the same issue, it's only when staying in that 5-7 MPH range.
I find that the car is only smooth in first gear when coasting at 4 MPH. Anything between 5-10 MPH is very jerky, and I haven't really tested 10+ MPH because at that point I shift into second gear anyway.
This leads to it being very annoying and difficult to drive or coast slowly in parking lots, or in stop and go traffic. I will usually either have to coast in neutral or keep the clutch pressed, or shift to second gear quite low in its usable range and be forced to disengage the clutch/go into neutral/go back into first quite often when I need to slow down.
Any advice is greatly appreciated!
