Upper control arm/tie rod end removal?
Superhatch
Jacob
Wisconsin
2025 RR FL5 CTR, 2025 Civic Hybrid, 1991 CRX Si, Honda Monkey
So I damaged the axle seal in my trans on the drivers side when doing a lowering spring install and now I'm looking to replace it.
The UCA/Fork and outer tie rod end bushing are a bit different than I'm used to (EK/EF/EG/etc) and I'm not sure if I need a tool or if people just loosen the nut to the end of the threads and give it whack?
Maybe there is another way to remove the axle? I'd really like to not separate the strut from the 'UCA' because it was so terrible to get back in.
There is a LCA tool but it's $350+shipping and I'd like to avoid that if possible. Any help is greatly appreciated.
