*The FL5 Track Junkie Thread*
BigBird
MooMoo
where did they leak from?
also I forget but 15psi? I think I do like 10 or 12 but I forget
BigBird
the fitting. My VW needed high PSI to work right with the ABS and never had an issue. Never though of using less than that...I like to see the needle hit the limiter :D
MooMoo
BigBird
svvitch
Matt
haha I have that bottle too.
You could always get some of these
https://www.stahlbus-us.com/bleedin...ahlbus-bleeder-valve-m10x10x16mm-m-steel.html
I would 100% get these if I was bleeding my brakes more than once a year. The brembos are as soft as cheddar cheese and constantly opening and closing the bleeder will probably eventually start leaking.
AP Racing has a fix for me. I can tell my wife I just need to replace the calipers, and AP is cheaper than factory ?
TW00Si
NYC
2007 S2000, 2023 CTR
Anyone have the part number for the front brake rotor? Just the replacement, not including the center piece.
MooMoo
I don't think honda sells just the disc, you need to buy the whole thing. Dumb I know.
But I think paragon sells just the disc that will work with the OEM hat
TW00Si
NYC
Fug. Then I think that’s my excuse to get the girodiscs. ?
MooMoo
yep...
and your bleeder will start leaking and you can get the AP calipers too :D
TW00Si
NYC
Nah…I will get the bleeders you guys linked.
