PRL Motorsports Coolant Overflow Reservoir Tank 2022+ Honda Civic (1.5T & 2.0L) Now Available
PRL Motorsports
Premium Performance Products
Export, PA
prlmotorsports.com
The PRL Motorsports aluminum Coolant Expansion Overflow Tank replaces the unattractive, factory plastic tank with this sleek and sturdy aluminum tank that better fits the aesthetics underneath the hood of your car. The internal volume of our Coolant Expansion Tank is equivalent to the factory tank, resulting in no coolant loss.
Our expansion tank is constructed of TIG-welded, 3mm thick aluminum and anodized gloss black durability. Each tank includes a billet aluminum cap, sight glass and custom lower fitting to fit the factory coolant line. This kit requires no modification for installation and reuses all factory hardware.
Over time, heat cycles and age can cause plastic coolant tanks to fail. Fortunately, our aluminum replacement improves heat-transfer due to its superior thermal conduction properties, and resists high coolant pressures commonly associated with race engines!
Technical Notes:
  • (1) 1-Piece Aluminum Tank w/ Integrated Mounting Bracket
  • (1) Adapter Fitting
  • (1) Billet Overflow Cap
  • (1) Sight Glass
11th Gen Honda Civic PRL Motorsports Coolant Overflow Reservoir Tank 2022+ Honda Civic (1.5T & 2.0L) Now Available PRL_CoolantReservoir-5
11th Gen Honda Civic PRL Motorsports Coolant Overflow Reservoir Tank 2022+ Honda Civic (1.5T & 2.0L) Now Available PRL_CoolantReservoir-6
11th Gen Honda Civic PRL Motorsports Coolant Overflow Reservoir Tank 2022+ Honda Civic (1.5T & 2.0L) Now Available PRL_CoolantReservoir_Install-13
11th Gen Honda Civic PRL Motorsports Coolant Overflow Reservoir Tank 2022+ Honda Civic (1.5T & 2.0L) Now Available PRL_CoolantReservoir-1
Ucalyptus
Ulises
US
Fk7
Technical Notes:
  • (1) Sight Glass
Will this or the type r coolant expansion tank fit the FK7 hatchback sport?
Chilly613
Southern California
2025 FL5 Civic Type R
