- Jan 26, 2017
- 70
- 1,100
- 1,001
- Export, PA
- Website
- prlmotorsports.com
- 2022 Civic Si, 2023 Civic Type-R
After many inquiries, & the popularity of the Cobra on the 10th gen 1.5t platform, we decided to make a Cobra Cold Air Intake System that is compatible with the 11th gen Si! We took our classic Cobra back to the drawing board & made the necessary changes needed to properly fit the intake to the 11th gen Si. This ensures proper fitment & performance that is expected with PRL. We are excited to give you guys another option, & YES our PRL inlet pipes are compatible with this intake.
Overview
Our Cobra Cold Air Intake System for the 2022-2025 Honda Civic Si 1.5T is a complete cold air solution engineered to bring maximum performance and clean, aggressive induction sound to your 1.5L turbocharged platform. This system pulls fresh, dense air from the lower driver-side bumper duct—well outside the engine bay—to promote cooler IATs and more consistent power delivery.
Engineered for both performance testing and everyday drivability, this intake system delivers dependable gains with the same proven quality behind every PRL product.
Performance Gains
Dyno testing confirms that even without a tune, this system brings measurable improvements in power, response, and sound. Tested on a completely stock Civic Si without tuning, our Cobra intake delivered up to:
- +16 horsepower
- +9 lb-ft of torque
- Gains sustained throughout much of the RPM range
- Peak improvements measured at key points in the powerband
The yellow lines show the Cobra Intake; the green lines show the stock airbox.
Key Features
- True cold air design – Draws air from outside the engine bay
- Billet 6061 Aluminum MAF Housing – CNC-machined for OE-like fuel trims; anodized black finish
- HDPE Rotomolded Lower Intake Tube – Lightweight, durable, and thermally efficient
- Stepped Silicone Couplers – Smooth internal transitions for optimal flow
- Resonator Delete Integration – Includes plug for factory cold-side resonator box
- No Tune Required – Standard bore MAF housing maintains factory fueling
- 304 Stainless Steel Brackets & Hardware
- 4-Ply Silicone Upper Hose
- 6-Ply Silicone Lower Hose
- Stainless Clamps
- High-Flow Oiled PRL Cone Filter
- (1) Rotomolded Lower Intake Tube
- (1) 4-Ply Upper Silicone Hose
- (1) 6-Ply Lower Silicone Hose
- (1) Billet Aluminum MAF Housing
- (1) High-Flow Oiled PRL Air Filter
- (1) Upper Mounting Bracket
- (1) Lower Mounting Bracket
- All necessary clamps and fasteners
- (1) Rubber Resonator Delete Plug
- (1) PRL License Plate Frame
- (1) PRL Lanyard
- (2) PRL Stickers
- 2022–2025 Honda Civic Si 1.5T
- May fit additional 1.5T Civic variants
