jcm
- Dec 22, 2024
- 8
- 72
- 47
- Los Angeles, CA
- 2025 FL5 Honda Civic Type R
sup everyone, I recently made the mistake of comitting a custom tune to flash with a brand new laptop that had not yet had power and sleep settings configured, the laptop went to sleep and interrupted the transfer. I was successful in uploading the tune afterwards under the condition that i did not turn off the ignition under advice from my tuner and then simply perform a reflash. this appears to have worked as the type s burble configuration is still working. however in days following this incident, there has been a common deviation of around +/- 8 pounds for boost commanded versus boost actual. should I be doing a "return to stock" and then a reflash? would that even help? I am also investigating the physical potential for boost leak as obviously that would be the other implication there from booost command versus boost actual showing a common delta. any thoughts? am i on the right track
