sucks that they are removing start-stop. the pre-production one for media test drive still has the button.. (might be a place holder I guess)All you need to know about the new FL5
Huge shout-out to Creative Trend, if you want to know more about the equipment and safety features (although for JDM spec), please visit - https://creative311.com/?p=144616
◇Body size: Total length 4,595mm (+35mm) x Total width 1,890mm (+15mm) x Total height 1,415mm (-20mm)
◇Wheelbase: 2,735mm (+35mm)
◇Track width: Front 1,625mm (+25mm) Rear 1,615mm (+20mm)
◇Body weight: 1,430 kg (+40 kg)
◇Minimum ground clearance: 125mm (±0mm)
◇Minimum turning radius: 5.9m (±0m)
◇Engine: 2.0L K20C1 inline 4-cylinder VTEC turbo engine
◇Maximum power: 330ps (+10ps) / 6,500rpm
◇Maximum torque: 420 Nm (+20 Nm) / 2,600rpm to 4,500 rpm
◇Gear ratio: 1st gear 3.625 / 2nd gear 2.115 / 3rd gear 1.529 / 4th gear 1.125 / 5th gear 0.911 / 6th gear 0.734 / Reverse gear 3.757
◇Final drive: 3.842
◇Compression ratio: 9.8
◇New engine modification: Direct injection engine, variable valve timing, newly designed and lighter turbo blades to reduce inertia and increase responsiveness, (complete removal of engine start-stop) "LOL Honda claims this is the ultimate version of VTEC Turbo"
◇WLTC average fuel consumption: 12.5km/L (-0.5km/L)
◇WLTC urban average fuel consumption: 8.5km/L (-1.3km/L)
◇WLTC highway average fuel consumption: 15.0km/L (+0.1km/L)
◇Fuel tank capacity: 47L (+1L)
◇Brakes: Front: hydraulic ventilated disc Rear: hydraulic solid disc
◇Suspension: Front: Dual axis McPherson strut Rear: Multi-link
Have the gear ratios been posted yet!?!??Final Drive is shorter than the FK8 it seems if this information is solid. Reading reviews of the FK8 and the mention of 3K RPM at 80mph wasn't my favorite. This may lower it a little bit.
right above your commentHave the gear ratios been posted yet!?!??
)right above your comment
◇Final drive: 3.842
I agree with you. I'm also skeptical but I would welcome the change. It seems that Honda has put effort into making the car more comfortable and friendly on a day-to-day basis. Does that make sense or do you think that is a reach? In the sense of 80mph highway travel.Sorry, I've been extremely anxious to see if Honda has manufactured any new gear ratios. I opened this thread for the first time in a few days hoping that the technical specifications had been posted. I read the words "final drive" and completely spazzed out with excitement lol.
The ratios posted are the same as the FK2. Same 1-6 gears as FK8, but taller, 3.842 final drive that Honda reused from the USDM 2010-2014 Acura TL SH-AWD 6MT.
I'm a bit skeptical about the ratios posted. I'm surprised that Honda went from the 4.11 final drive down to the 3.842 despite FL5 having a higher curb weight. The only thing that would make sense is if the overall tire diameter of FL5 is smaller then the FK8.
In case you're not familiar with the project I did with these trans, here's a link my project thread.
There is nobody, literally nobody that you will ever be able to find that has spent more time reverse engineering these transmissions with exception to someone that has or was employed by Honda that was on the engineering team that designed these transmissions.
Let me know if you've got any questions.
https://honda-tech.com/forums/trans...-also-applicable-k-series-fk8-type-r-3346496/
Sounds about right. Here in the states 2002 Civic Si EP3 came with weak K20A3 engine. Everyone wondered why Honda didn't offer it with a better engine.I agree with you. I'm also skeptical but I would welcome the change. It seems that Honda has put effort into making the car more comfortable and friendly on a day-to-day basis. Does that make sense or do you think that is a reach? In the sense of 80mph highway travel.
