RUNN1N
- #1
When I traded my DE5 for the FL5, I immediately missed the DE5's illuminated door sills--bright, glossy, and located at the front and back doors. I had my dealership install the FL5 OEM door sills, but they're just sad--dim, orangeish-red, and only available for the front doors. C'mon, Honda!
I looked at some of the sills offered by other manufacturers, learned a bit about how they're constructed, put together a design, and hunted down a manufacturer willing to make a set of prototypes to my specs (in China, of all places, can you believe that?). They arrived about 6 weeks later, and I installed them last weekend using my OEM wiring harness and a few soldering heat shrink connections. I'm very pleased with the outcome, and I've been getting a surprising number of questions about selling them... so I'm here to gauge interest.
A few disclaimers: A future run will be the same size/shape/layout but will have the Type R logo on a black background, not the FL5 camo--it will give the Type R logo more pop when it's dark, similar to the Integra illuminated sills. Install will require running Honda's illuminated sill wiring harness (~$30) behind the dash, and will also require (very basic) wiring skills--ie snip the OEM sill plugs, and wire in the sills using your choice of connection type (heat shrink solder sleeves or Wago connectors, for example). This will be for all 4 doors, not just the front doors--running the harness behind the dash is the tedious job (in my opinion), and placing the for both doors sills only requires removing ~4 pieces of trim on each side, loosening the weather stripping, and a little body tape.
I'm expecting the cost with freight and duty to come in around $300/set + Shipping, but I'd need about 25 orders to justify the work. If it seems like there's enough interest, I'll share a mockup of the sills in black, I'm sure you already get the idea.
Comment if you're interested--I'd do a poll, but it seems silly.
