OEM Fender/Hood Gaps Not Symmetrical?
pigfacedalarm
I did some googling, did not see anything for the FL5 but saw this was an issue with the FK8, so I assume it carried over to the FL5 but would like confirmation.
My left side (drivers side in US) has a slightly larger gap between the fender and hood than the right side. When I mean slight, I mean approximately 1-1.5mm larger gap. I know it fits within the industry standard tolerances for body work, but I just noticed it and wanted to see if this is widespread?
I refuse to make any adjustments since I know that’ll probably throw something else off, plus it’s very minor. But extremely curious if I’m just unlucky or it’s still an issue with the FL5 assembly.
Shrapnel
Justin
Los Angeles
CW 2024 Civic Type R #16838
My FL5 has this drivers side hood gap too, and it really bothers me. Is there any way to adjust the hood or is this just never going to be fixable? I can’t upload a pic - even after resizing
yeaitsahonda
David
Virginia
2023 Boost Blue Type R
Loosen the bolts from the hinges to the hood and you can adjust it there.
Shrapnel
Justin
Los Angeles
Ok thank you, surprised mine got through like this, seems really bad. Or maybe I’m just way too OCD
RP2000R
WA
23 CTR, 21 Porsche Cayman GT4, 15 Lexus IS350 RWD
I am ocd and my FK8 was horrible and also had paint issues and blemishes all over. My FL5 is way better quality and gaps improved.
Passenger side of my hood was down a hair lower then the fender so I adjusted that via the rubber adjusters under the hood.
My hatch is my biggest issue with my passenger side definitely bigger then the drivers side along the roof line. I didn’t see a easy way to adjust it so I’ll let it go hahahaha.
Shrapnel
Justin
Los Angeles
I‘m afraid to even look at my hatch now ?
