No fog lights on USA Si’s - OEM or Aftermarket options?
Krebsy718
David
Connecticut
2020 VW Cross Sport
So seeing that the USA model SI’s do not come with fog lights but it looks like there is room I’m wondering if there are any aftermarket companies that have options for them. Also, I’m questioning how easy (or hard) will it be to wire and set up any aftermarket lights. Any general information is much appreciated. Thanks
SDAlexander8
Steve
Indianapolis, IN
2017 Civic Si Coupe
The 10th gen models that didnt come with fog lights had kits available that required removing the bumper, running a wire along the crash bar and through the firewall to the drivers footwell and plugging a connector into 1 of several available accessory ports down there.
All plug and play. It took me 6-8 hours with 0 experience.
The kit also replaced the turn signal stalk to one with the fog light switch.
Cost was around 350$. Idk what the 11th gen kit will cost.
Shankmeyster
AZ
23 Type R
Maybe you'll be lucky enough that they have the wiring in them so you just need to plug it in.
HardLuckFE1
Morgan
‘22 Civic Si
