jcm
- Dec 22, 2024
- 8
- 72
- 47
- Los Angeles, CA
- 2025 FL5 Honda Civic Type R
Hi guys.
Just recently got my ECU unlocked and slapped a 91 base map on the ecu accounting for the current bolt ons I've got.
PRL hvi
PRL charge pipe
PRL intercooler
now, when I really stomp on it on the highway in 4th gear and hit higher RPM ranges and then shift up to 5th,
or just generally lifting at all after stomping on it, the resulting BOV noise has changed.
it no longer sounds like a clean exit of air.
it sounds strained and harsh. it's making me a little nervous.
the hondata tune does alter the maximum boost pressure and I believe there is an option for this.
from what i've seen, it's going up to around 24 pounds of boost after tune. previously maxed out around 20 pounds of boost.
am I headed for trouble with the stock BOV? I believe the stock valve is plastic.
any input greatly appreciated.
EDIT: important to note - the strain noise does not occur every lift. it is intermittent.
i assuime it is likely tied to events including boost pressure towards the above-stock new cieling at around 24 pounds.
PRL hvi
PRL charge pipe
PRL intercooler
