blueroadster
I never really understood the need to pump coolant through the throttle body so it is time to eliminate it. Here is the parts diagram for the FL5 (throttle body coolant hoses are parts 1, 2, and 3):
Parts 1 and 2 in the above diagram connect to the throttle body barbs (E-15-12):
The hard pipe (To E-8-2 in the first diagram) has an 8mm OD for the coolant hose connections:
8mm = 0.315" so 5/16" or 3.125" ID end plugs can be used to cap off the coolant hose connections on the thermostat case (i.e., where parts 1 and 3 connect in the first diagram). End plugs can also be added to the throttle body barbs to cap them off.
