siwelnosaj
Ok so an update from this past weekend's track day at Laguna Seca. I will start by saying I'm pretty pleased with all the numbers and I feel like it's a very strong starting point, but yes I do think there's room to improve and I have some ideas on how to achieve this.
Anyways, so here's the numbers as a comparison to my fk8. All of these are with full 20 minute sessions pushing the whole time after the tire warm up:
- V1 fk8 set up, 67° ambient, 242 peak ECT, 259 peak oil, best time of 1:36.68. Stock turbo, e25 approx 410whp
- V2 fk8, 67° ambient, 222 peak ECT, 240 peak oil, best time of 1:34.57 (fk8 lap record), Stock turbo, e25 approx 410whp
- FL5, 62° ambient, 231 peak ECT, 263 peak oil, best time of 1:38.06 (optimal of 1:37.0, but I was way too conservative in a number of braking zones and corners, and sloppy in a couple of others), MHI turbo, e25 approx 435whp (losing ~ 15whp due to having to run restrictive OEM exhaust cause of 90db day)
Also it's worth noting that the calculated oil temp compared to what I was getting from my physical sensor, there was a 25-35° delta at any given time with the calculated always reading higher. It's important to point out I'm not sure how much the dual oil coolers and running 5w30 oil are screwing up the car's calculations, I just know that on my set up it's way off.
I have the TCR vents on the OEM hood, I'm sure they are on some level helpful as well.
My assessment is that I need to open up my inlets to the oil coolers to take in a greater volume of air. In my last picture you can see the green lines are what I'm thinking, but I need to find someone to help me create the ducts I have in mind via 3d modeling/printing.
I think this will lower the oil temps and in turn also lower the coolant temps at the same time.
All that said I'm very pleased overall. Car was able to run full sessions at pretty aggressive paces at good power levels. No the ambient temps aren't high, but anyone that knows Laguna knows that it is very demanding on the car with all of the elevation changes, a day in the 60s there can be similar to a flatter track in the mid to low 80s.
Anyways, here's some pics:
