It's really not necessary for any climate in the U.S. to stray away from the factory coolant. I run the factory coolant in the off season. So no need for additives, the engine simply isn't going to get hot enough to cause damage.Any opinion on Mishimoto Liquid Chill for general use? It’s advertised to mix with any coolant and one bottle for our (FL5) engines. I’ve used Water Weter too and had zero problems, but only minimal cooling.
What about 116 degree California weather, do you think I can get away with no additives? ?It's really not necessary for any climate in the U.S. to stray away from the factory coolant. I run the factory coolant in the off season. So no need for additives, the engine simply isn't going to get hot enough to cause damage.
If you attend several track events during the spring/summer/fall then I'd swap out the factory coolant for something that can handle more thermal capacity, and then at the end of the season you would drain it out and refill with regular old factory coolant. I tested my go-to coolant mixture for track use and it is only good down to 10 degrees Fahrenheit without freezing. The factory coolant is good for temperatures that drop into the negatives.
You're going to want a mixture. 1 bottle of water wetter, 1 gallon of distilled water and fill the remaining capacity with factory coolant.What about 116 degree California weather, do you think I can get away with no additives? ?
So a complete drain then fill with the above? Can I get away with just adding the water wetter to my factory coolant?You're going to want a mixture. 1 bottle of water wetter, 1 gallon of distilled water and fill the remaining capacity with factory coolant.
I'd drain it if you have 116 degree tempsSo a complete drain then fill with the above? Can I get away with just adding the water wetter to my factory coolant?
