Burning smell after a pull
Roberto
Ontario
2022 Honda Civic ST 6MT 1.5t Sonic Grey
22 civic hatch st 1.5t 6mt is Ktuned, RMM 90A, SRI & snorkel. I run 94 supreme and only ran 91 since brand new. Currently sitting at 80xxx. I’ve driven this car hard plenty of times before tuning and never any hint of smell. And now it’s tuned this is the second time a smell has been noticed after a short pull. Oil was dark and fuel smell, coolant was low. No leaks ever noticed and guard under engine was always clean with no sign of leaks
cryptolime
Wilmington, NC
2023 Civic Si
probably the clutch slipping.
Two Step Performance
twostepperformance.com
Why would you tune the 1.5?
Probably because he likes fun. :p
This is a good lead to investigate. If the engine RPMs increase without the vehicle speed increasing accordingly, the clutch is slipping. This can be easily illustrated in a datalog if there are any doubts.
Roberto
Ontario
I have maybe 10-15% throttle pressure just to get the car to move. Any more throttle the rpm will spike and the car bogs or stutters
Roberto
Ontario
It still shifts in and out of gear smooth tho?
If you feel it is safe to do so, please upload a datalog of a wide open throttle pull in third gear and we can take a look to determine if the clutch is slipping or not.
Integra23
2023 Integra 6spd A-Spec
I noticed clutch slipping when I had my 1.5 and tuned. It's one of the weak points that you will need to upgrade.
Shankmeyster
AZ
23 Type R
If you haven't upgraded the clutch in 80k miles then it's the clutch. Hell it's probably the clutch at 10k miles.
