Hey! I just removed my downpipe last weekend and 0 broken studs.Seems like there is a high chance of this happening - any advice to avoid it?
Don’t forget the heat. It will really help with breaking the bolt loose with little chance of snapping.thank you - i will hit the studs with some kroil. The best stuff there is imo beats PB blaster by miles
Agree the titanium studs went in like butter and look so nice.Unfortunately broken studs can happen, even if you are careful. I've done countless downpipe swaps and thankfully have only broken one stud. It was on our FL5 with only 200 miles on it.
We used a carbide burr to cut out the rest of the stud, being careful to avoid damaging the treads in the turbo. Replaced the studs with titanium studs and have been golden since. The downpipe has probably been removed a dozen or more times since with the titanium studs.
https://www.twostepperformance.com/products/titanium-exhaust-stud-kit-for-honda-1-5t-and-2-0t
It would be nice if we could get Honda to start using titanium at the factory!
When I put everything back together I did that same thing. Anti seize the world?the earlier you do this the better; remove a nut, apply anti seize to threads, retorque, move on to next nut. it will save you in the long run.
I soaked the crap out of the top right stud and tried to double nut it to get it out so I can replace with the TSP titanium studs. No luck and it won't budge at all. Got the bottom left (hot side) stud out without any problem at all. Maybe I'm being too careful since the top right stud is in the part of the turbo with no access to the rear of the stud. I'm thinking I'll just replace the other 3 with the titanium studs and use a titanium nut on the factory stud I can't get out.Soak, soak, and soak again with with whatever lubrication you choose.....you be fine..it's pretty simple, it's not rocket science...Hahahahahha.
@Jester04 , what do you think I should do?I soaked the crap out of the top right stud and tried to double nut it to get it out so I can replace with the TSP titanium studs. No luck and it won't budge at all. Got the bottom left (hot side) stud out without any problem at all. Maybe I'm being too careful since the top right stud is in the part of the turbo with no access to the rear of the stud. I'm thinking I'll just replace the other 3 with the titanium studs and use a titanium nut on the factory stud I can't get out.
