Track Alignment Specs for FL5 Civic Type R (Full RV6 Suspension)
Boostblue965
Hashim
Kuwait
Type r 2023
Hey everyone,
I’m looking for advice on the best alignment specs for my 2023 Honda Civic Type R (FL5). The car is equipped with a full RV6 Performance suspension setup, and I’ll be running it mainly on track (Kuwait Motor Town) with occasional street driving.
Specifically, I’d like recommendations for:
  • Front Camber, Caster, Toe
  • Rear Camber, Toe
  • And importantly, what’s the best rear sway bar setup for track use with this platform?
My goal is to maximize grip and balance for circuit racing while keeping the car predictable and stable. Any input from those with track experience on the FL5 (or similar FK8 setups that translate well) would be really appreciated.
Thanks in advance!
Bat1
Sebastien
Burleson
FL5 m340i
Following up, I'm interested with this topic!
Also can you share what RV6 suspension did you upgraded to?
AspecR
Stefan
Hey everyone,
  • Rear Camber, Toe
Thanks in advance!
Try these out, couple FK8 guys I know used this as a base and adjusted to their preference
Front Camber: 3.5 deg
Front Castor: 7.3 deg
Front Toe: zero to -0.02in depending on preference
Rear Camber: 2.5 deg
Rear Toe: 0.07in or zero it out if you prefer a more loose rear end
Question about front camber, Is yours adjustable from a camber plate on the strut tower or through a lower adjustable ball joint or both?
Boostblue965
Boostblue965
Hashim
Kuwait
Type r 2023
thnak you so much for your response , regarding the front camber I’ve used adjustable lower joint from EVS
Boostblue965
Boostblue965
Hashim
Kuwait
Type r 2023
RV6 Solid Front Compliance Mount for 22+ Civic
RV6 Adjustable Rear Lower A Arm (Adjusts Camber) for 2016+ Civic / 2023+ Integra
RV6 Adjustable Rear Lower B Arm (Adjusts Toe) for 2016+ Civic / 2023+ Integra
RV6 Adjustable Chromoly Rear Sway Bar Kit for 16+ Honda/Acura - with Endlinks
rv6 rear knuckle spherical bearings
And i got the eibach pro kit lowering springs
AspecR
Stefan
Nice list, have you done Spoon or PRL Rigid collars? They help maintain alignment under load.
Boostblue965
Boostblue965
Hashim
Kuwait
Type r 2023
Yes i had the prl rigid collar the car now is much stiffer
