So I have it logging, is that the same as communicating?Have you reached out to support?
More often than not the unit is asleep. If it's a V2 often the USB port is not giving it enough power.
Very easy to tell.
V1.2 - If the LED isn't on.
V2 - If you touch the screen and it doesn't turn on for a split second. Or if it's stuck on the boot screen, etc.
If all else fails, simply unplug it from all power sources and plug it back in to reset.
It will read uploading if you've put the tune into a tuning slot. It will say flashing if you're flashing direct the ECU.So I have it logging, is that the same as communicating?
Also it will "Prepare" and the go straight to "Uploading"
I thought it was supposed to prepare,erase ecu, then upload?
I've downloaded the new version btw, thanks!
