Seat Creaking
Mimzie2763
Parker
North Carolina
1997 Toyota Supra Turbo 6MT, 2023 FL5
Has anyone had any issue with their drivers seat creaking? It’s mostly in the bolsters.
2023 GR Yaris - Circuit Pack
Second or third person encountering this already? - Does Honda issue TSB’s?
Bsnyder6
Virginia
2023 Civic Type R, 2005 Wrangler
Mine started squeaking after 2 weeks. it's progressively gotten worse. Every slight movement makes noise
Mimzie2763
Parker
North Carolina
I guess I will be taking it in some time soon. Hopefully they find the problem
Bsnyder6
Virginia
Got an appointment this weekend for mine. It seems to be the plastic around the adjustment handles. If I push on it..it seems to decrease the squeaking.
Bsnyder6
Virginia
Just an update. Had the car at the shop this morning. They've order a new inner frame. Seems like that's the common solution for all of our squeaky seats
PA, USA
2022 Honda Civic Si, 2000 Honda Civic LX
Mine squeaks and creaks on my Si. It took me a while to isolate the sound, as originally I thought it was the pedal box. Then I figured it was the steering wheel after messing around with the pedals and not replicating the sound. Finally came to the conclusion it was the seat, and pushing in the pedals and turning the steering wheel resulted in me shifting my weight.
I adjusted the seat to sit up higher, at the top of the range of motion, and pushed it back slightly to be more comfortable, and it’s disappeared entirely. Try adjusting the seat to sit higher off the floor, if only as a temporary fix while you get it officially repaired.
