SCCA Street Touring/TT Tuner Sharing Thread
BigBird
It is coming together but with some hiccups.
I just got the JRZ suspension in but tried the Vitour tires up front and there were pretty bad.
Not only did they need heat to function but once they got up to temp, they would drop off toward the end of the run. This is with the 315s on an 11" wide wheel. I think I either got a bad batch (shipped from LV address that was rumored to be questionable, but Vitour USA vouched for), the size/wheel width combo isnt ideal for the car, or the tires just need a true full heat cycle and rest before they come in.
Then to top it all off my turbo blew :mad:
Hopefully I will have a chance to get some better seat time with the car next weekend after everything is all patched up.
The real high point of the build so far has been the OS diff.
I am having to re-learn the new threshold for aggressive early throttle.
Other than the occasional clunk at full lock, it has been quiet on Motul 75w90 fluid.
Lots of lessons there. Thanks for being a tester.
What happened with the turbo? Tune issue? Bad luck? Running a flame tune ? ?
I was thinking of go going with the Cusco 1.5 but I heard good things about the OSG on other platforms.
Sucks about the Vitours. If it's a bad batch, then shame on them, if they just don't work on this car, that also sucks.
Hopefully you'll get things squared away soon
