Rocks in rotors - making annoying noise
Kfo_cpa
Chicago
RDX
Has anyone else had bad luck getting rocks stuck in their rotors? It happened to me twice. I was able to push the guard behind the rotor and I heard the rock fall, but the second time I feel like a small piece is stuck somewhere because I can hear a little scratch/whistle noise. It’s strange because I only seem to hear it when I let off the gas and I’m coming to a stop. If anyone has any suggestions please share. Thanks.
CTR
WA
strixauto.com
2023 Civic Type R, 2020 GX460
It's probably the electronic wastegate and not a rock.
If it makes the noise even when you're not pushing on the brake pedal it's probably that. If so as soon as you go on throttle it should go away.
Kfo_cpa
Kfo_cpa
Chicago
RDX
That might be it and maybe I’m just noticing after the rock incident. Is that a pretty constant mild sound/whistle noise when you let off the gas? I mainly hearing it when I’m decelerating from 3rd and 4th gear. I thought it was something mildly rubbing coming from the front left tire.
Rhorn
Robert
BRZ, Civic Type R
Its definitely the e-gate.
Lightweight
Tony
Toyota Corolla
I had it in my Porsche Macan. I parked the car, turned the wheel left and right couple times, and then it went away. I presume the rock was loosened.
