Rear Motor Mount – 6 MT – Boomba Racing
Boomba Racing
Civic X Vendor
Wood Dale, IL
www.boombaracing.com
2017 Civic Sport, 2018 Civic Type-R, 2010 Civic SI, 2015 Civic SI,
Our rear motor mount for the 6 speed manual is officially available now!
Link to buy: http://www.boombaracing.com/2016-honda-civic-rear-motor-mount-6mt/
Install guide: http://www.boombaracing.com/content/CIVIC X - MOTOR MOUNT MANUAL.pdf
-----------------------ORIGINAL POST-----------------------------
Boomba is no stranger when it comes to motor mounts for Honda Civics. We’ve made mounts for the European Type-R’s, R18’s, 8th Gen & 9th Gen Civics in the past. Now we are looking to expand with the tenth generation Civic.
You may be questioning “what is a rear motor mount” or “why do I need to replace my rear motor mount?”. Let us educate you a little bit on that matter.
A rear motor mount secures your engine to the subframe. From the factory these mounts are fine for normal driving but often leave a lot to be desired in the terms of performance. Stock mounts are sloppy and result in a lot of flex. This gives you undesirable things such as wheel spin, torque steer, wheel hop, and awkward feel when shifting.
The Boomba Racing Motor Mounts feature a poured in polyurethane bushing rather than a pressed in one. The benefits of this can be seen here in this video:
I’ve attached a picture of our in-development mount below!
These are set to release very soon.
Let us know if you have any questions
11th Gen Honda Civic Rear Motor Mount – 6 MT – Boomba Racing 31126789614_22891a6ed2_
maaaaackle
Socal
Sport Hatch 6MT
I'm excited for all the products you guys are putting out.
Definitely gonna pick up the BOV once it's released. :thumbsup:
Boomba Racing
Boomba Racing
Civic X Vendor
Wood Dale, IL
Does that fit the 2.0? It seems there is not that much mods for this engine :(
Yes! This will fit on the 2.0. We've designed two different mounts. One that works on all manual transmission tenth gens, and one that works on all CVT tenth gens!
Boomba Racing
Boomba Racing
Civic X Vendor
Wood Dale, IL
Boomba Racing
Boomba Racing
Civic X Vendor
Wood Dale, IL
Jesus...
The stock mount looks like it's made out of rubber in that video...
Now you can see why its such a good idea to upgrade this piece!
Boomba Racing
Boomba Racing
Civic X Vendor
Wood Dale, IL
Boomba Racing
Boomba Racing
Civic X Vendor
Wood Dale, IL
Features:
-Molded in polyurethane bushing
-Eliminates wheel hop
-Increases traction
-Eliminates “bang shift”
-Premium aircraft grade billet aluminum
-Reduces engine flex
-80 durometer bushing
These direct bolt-on mounts combine to replace the rear engine torque damper, significantly improving the vehicle’s traction and shifting response by reducing excessive engine flex. Wheel-hop during hard launches is also completely eliminated thanks to these mounts.
Boomba Racing mounts are machined from high quality aircraft grade billet aluminum for strength, durability and looks. Inside each mount you’ll also find solid poured-in polyurethane bushings with the rigidity carefully chosen to optimize vehicle stability while also minimizing excessive vibration transfer from the motor to the body.
Installation is simple, does not require engine support and utilizes all OEM hardware.
Available in your choice of color: Black, Blue, Red, or Pure Aluminum
11th Gen Honda Civic Rear Motor Mount – 6 MT – Boomba Racing 31423719363_8c302768c8_k
Boomba Racing
Boomba Racing
Civic X Vendor
Wood Dale, IL
