Progress 20.6mm Rear Sway Bar |
kseriesparts
Colorado
Attention Tenth Gen Civic owners! You purchased a brand new Civic…it handles nicely and rides great, but has a bit too much understeer and traction-robbing body roll. Be happy. Progress Tech has just released a new Rear Sway Bar. This upgrade will improve the chassis balance and add that new level of control that you are looking for.
This larger 20.6mm Progress Sway bar will reduce body roll and improve steering response. Progress engineers have developed this rear sway bar upgrade for your new daily driver, promising superior performance, quiet operation and unmatched durability. It's a quick & easy installation, just six fasteners and you will be rolling in minutes, not hours. Just install, torque to specs, and hit that favorite twisty road!
Direct fit for 2016+ Honda Civic
11th Gen Honda Civic Progress 20.6mm Rear Sway Bar | 62-1027
Payments as low as $15.82/month
Benefits:
Progress .812" (20.6mm) dia. precision-bent 4130 alloy sway bar.
Poly bushings and lateral location rings for instant sway bar response.
New bushing brackets with TIG welded gussets for zero tear-out.
Powder-coated sway bar & brackets for superior appearance & durability.
Complete kit includes bushings, brackets and synthetic chassis lube.
Designed for use with the OEM end links.
Made in the USA.
kseriesparts
kseriesparts
Colorado
11th Gen Honda Civic Progress 20.6mm Rear Sway Bar | 60-1027-1_750x500
Features include the following:
  • Progress .812" (20.6mm) dia. precision-bent 4130 alloy sway bar.
  • Poly bushings and lateral location rings for instant sway bar response.
  • New bushing brackets with TIG welded gussets for zero tear-out.
  • Powder-coated sway bar & brackets for superior appearance & durability.
  • Complete kit includes bushings, brackets and synthetic chassis lube.
  • Designed for use with the OEM end links.
  • Made in the USA.
kseriesparts
kseriesparts
Colorado
$174.99 Shipped
Benefits:
Made in the USA.
kseriesparts
kseriesparts
Colorado
This will fit the hatchback model?
-R
I just got off the phone with the very nice people at progress, and they said it would fit the hatch.
bembol
SHIFT_
Rafael
GTA
17 FK7 Sport Touring, 20 Audi Q3 Progressiv
How much bigger is it compared to stock?
Not sure if I want to drop it but just upgrading this you'll feel the difference right?
kseriesparts
kseriesparts
Colorado
OEM 17.0mm dia. Solid sway = 280 lbs/in.
Progress 20.6mm dia. Solid sway = 550 lbs/in. (96% increase)
hawk02
Far away
2017 Civic Si Coupe
Does the Sport HB have the same rear bar as the sedan/civic? I thought the Sport had an upgraded front and rear bar, front for sure.....
kseriesparts
kseriesparts
Colorado
Benefits:
Made in the USA.
kseriesparts
kseriesparts
Colorado
I ordered it from you guys the other day anyway lol.
You know what to do lol. Please let us all know if it fits. It's community service :)
