PRL Motorsports Shifter Bushing Upgrades Now Available!
PRL Motorsports
Premium Performance Products
Export, PA
prlmotorsports.com
11th Gen Honda Civic PRL Motorsports Shifter Bushing Upgrades Now Available! PRL_ShifterBushing-Linkage-3
2007+ Honda / Acura Shifter Cable Bushing Upgrade
Fits most 2007+ Honda / Acura Models
Fits all 2007-2011 Honda Civic 6MT (DOES NOT FIT 2006 Civic)
Fits all 2008-2012 Honda Accord 6MT
Fits all 2009-2014 Honda Fit 6MT
Fits all 2011-2016 Honda CRZ 6MT
Fits all 2012-2015 Honda Civic 6MT
Fits all 2013-2017 Honda Accord 6MT
Fits all 2015-2017 Honda Civic Type R
Fits all 2015-2020 Honda Fit 6MT
Fits all 2016-2021 Honda Civic 6MT
Fits all 2017-2021 Honda Civic Type R FK8
Fits all 2018-2023 Honda Accord 6MT
Fits all 2022+ Honda Civic 6MT
Fits all 2023+ Honda Civic Type-R FL5
Fits all 2023+ Acura Integra 6MT
Technical Notes:
Over the years Honda has continuously been praised for their ability to design and produce quality transmissions with a great shifter feeling. What if we told you that there was an easy and cost-effective way to make your driving experience even better?
Improve shifter stability, bushing longevity and reduce cable-binding with the PRL Motorsports Shifter Cable Bushing Upgrade. This upgrade replaces the OEM rubber bushings and replaces them with a combination of 6061 anodized aluminum inserts and Delrin sleeves for increased rigidity and longevity. Delrin is a resistant to most chemicals and self-lubricating, which is perfect for shifter bushings.
Each kit utilizes a large spherical bearing to allow for 2-axis of movement and minimize wear while eliminating the chance of binding that other aftermarket options can cause. We designed the aluminum inserts in both bushings to feature machined index-grooves, which secures each bushing to the metal stud. Retaining a fixed position, like the factory bushings, was a key goal during development. This feature ensures that the bushing cannot prematurely wear from freely move around on the inner metal stud, unlike other aftermarket options. Our design also retains the factory approach of a multi-piece smaller bushing. This allows for all movement to be contained within Delrin sleeves, which drastically reduces wear. Integral O-rings are used on the outer sleeves of each bushing to provide a tight seal and feel.
Kit Includes:
  • (1) Large Spherical Bushing Assembly (Anodized 6061 Aluminum, Delrin & O-Rings)
  • (1) Small Bushing Assembly (Anodized 6061 Aluminum, Delrin & O-Rings
  • (2) Stainless Steel Retaining Rings
  • (2) Stainless Steel Cotter Pins
11th Gen Honda Civic PRL Motorsports Shifter Bushing Upgrades Now Available! PRL_ShifterBushing-Base-3
2016+ Honda / Acura Shifter Base Bushing Upgrade
Fits most 2016+ Honda / Acura Models
Technical Notes:
Improve shifter stability and precision shifting with the PRL Motorsports Shifter Base Bushing Upgrade. This upgrade replaces the OEM rubber bushings and replaces them with solid 6061 anodized aluminum inserts for increased rigidity and longevity.
Kit Includes:
  • (1) Set of (4) Shifter Base Bushings (Anodized 6061 Aluminum)
  • (1) Set of (4) Stainless Steel Flush-Mount Bolts
MSUGeoman
Josh
Tennessee
2023 Civic Type R #2486
Excited to pickup both, one of the best upgrades for a MT car, especially for the 1500+ miles I drive mine monthly on mountain roads. Checked PRL website and shows 4/6 expected in-stock date FYI for anyone interested.
H TYPE R
Donson
Dallas
2024 Civic TYPE R 2023 M3 COMP 2022 F150 Shelby
how hard are they to install?
PRL Motorsports
PRL Motorsports
Export, PA
prlmotorsports.com
For the FL5, the airbox, battery, hard charge pipe should be removed for simplest install. A section of the wiring harness will also need moved out of the way, but that is just a 10mm bolt & a couple clips. From there, you should have full access to the bushings to swap over. I would say it is about a 60min job on average with a stock car.
Snmtazz70
Matt
Miami
Type R
Bought the Acuity and canceled order with PRL. They look very similar other than the color.
