mbaapk
- First Name
- Mike
- Mar 30, 2022
- 24
- 2,208
- 2,276
- Twin Cities
- Pacifica
I live the idea of having an extra 40 hp below 3k that is on their maps.
Have to be careful with that. Just because you can make more power down below 3k rpms does not mean you should use it. Low rpms with high loads are a recipe for knock and premature ignition of the combustion.I live the idea of having an extra 40 hp below 3k that is on their maps.
Be careful how? I just like a little extra geddyup while tooling around. I figure if the gas is clean then should be fine no?Have to be careful with that. Just because you can make more power down below 3k rpms does not mean you should use it. Low rpms with high loads are a recipe for knock and premature ignition of the combustion.
I understand that people like the extra power down low for when driving around and most of the time its not an issue. But still it does put more strain on the engine. Look up LSPI and that should give you a bit more info. Honestly this is practice by manufacturers to make the car feel more peppy down low and to make the car more fun by using small turbos for responsiveness.Be careful how? I just like a little extra geddyup while tooling around. I figure if the gas is clean then should be fine no?
So you are saying Phaerable tune is set up to grenade?I understand that people like the extra power down low for when driving around and most of the time its not an issue. But still it does put more strain on the engine. Look up LSPI and that should give you a bit more info. Honestly this is practice by manufacturers to make the car feel more peppy down low and to make the car more fun by using small turbos for responsiveness.
Now from a performance and tuning standpoint you want to reduce low rpm high load scenarios as much as possible to minimize risk of Low Speed Pre ignition. That knock can kill engines. Most people that sell tunes won’t tell you that, they want that money. If you are looking for more power and responsiveness down low buy a N/A v8 car. I always suggest to my customers that even though the car is making more power down low to not use it if possible. I always try to counsel to be above 3k rpms if you are asking for power. And if you need to pass somebody don’t just mash the throttle on 6th gear while cruising and let the turbo pull you out. Drop a gear or two and then pass them to decrease engine strain.
Bigger turbos help with this due to increased lag, they kind of force you to down shift to get to the power band and decrease those low rpm and high load events.
No in no way am I implying that. I’m just saying that using that power down low increases the risk if something going wrong. Its up to the owner of the car to know how to operate it. Its not that the tune is unsafe, just the way that engines work.So you are saying Phaerable tune is set up to grenade?
Makes sense so no dig racing - which i dont do lol. Highway pulls are fine w the downshift.No in no way am I implying that. I’m just saying that using that power down low increases the risk if something going wrong. Its up to the owner of the car to know how to operate it. Its not that the tune is unsafe, just the way that engines work.
Partial throttle driving can be improved in a tune and you will feel it as more peppy around town and its safe. But once you start getting into boost that is when I mean you have to be careful.
This will be an issue with any tune from any person. Best practice is to drive it properly, keep it in the higher rpms when you actually want to accelerate quicker.
No you can dig race no problem. There is no real load on the car when its standing still and when you launch wheelspin keeps the load low too. So no issues there. Its more in mashing the throttle at 2k rpms on a higher gear like 4-6. On first and second the load won’t be as high.Makes sense so no dig racing - which i dont do lol. Highway pulls are fine w the downshift.
