KTuner V2 LED setup sheet (google sheet)
Crab
NW Florida
2018 Civic Si, 2002 Accord EX-L, 2003 Dodge Dakota
Hello everyone,
I created this spread sheet to simplify my LED setups. If you would like to use it also, select file > make a copy. This will place a copy in your google drive.
Duplicate master sheet & rename
Set your trigger (ect, iat, vss, RPM, map, etc) from the drop down.
Set warning type from the drop down.
Select custom color in KTuner software to record R,G,B values
Adjust and record limit settings
I have included my current LED setup on sheet 2. It operates as follows:
LED 1: When ECT is below 149; LED blinks blue. 150-220 is a sweep from a dim green to a slightly brighter orange.
LED 2-3-4: Sweeping shift light. All LED's start green and sweep to orange-red before reaching warning level with an intense red blink. This still needs some work on limits.
LED 5: Gives a vague idea of IAT. Could definitely use some more work on range & color.
Sheet: https://docs.google.com/spreadsheets/d/1dmktnuaGPfTHqjKPQyl6u75TpWV4J6Yp-4qQLNCHFVk/edit?usp=sharing
Gif of my setup: https://imgur.com/a/MsMBaDg
Hope you enjoy,
Crab
Stratman49
Steve
Santa Clara
2017 Honda Civic Si Sedan
Hey Crab,
Thanks, just copied your LED layout to my Ktuner LED set up for my Aegean Blue Si Sedan Nice work! Thanks!:)
Crab
Crab
NW Florida
Hey Crab,
Glad you liked it :)
It would be cool to get a bunch of interesting setups linked here.
knadsady
2018 Civic Si Sedan
Here's my setup:
https://imgur.com/a/JfN97VR
Settings:
  • Type: RPM
  • Warning Type: Above Threshold
All LEDs:
  • Warning Value: 7000 | Intensity: 70 | Color: Red (RGB 255,0,0)
  • Cutoff Value: 0
LED 1:
  • Starting Value: 2500 | Intensity: 0 | Color: Blue (RGB 0,126,255)
  • Ending Value : 3499 | Intensity: 40 | Color: Blue (RGB 0,126,255)
LED 2:
  • Starting Value: 3500 | Intensity: 0 | Color: Green (RGB 0,255,0)
  • Ending Value : 4499 | Intensity: 40 | Color: Green (RGB 0,255,0)
LED 3:
  • Starting Value: 4500 | Intensity: 0 | Color: Yellow (RGB 255,255,0)
  • Ending Value : 5499 | Intensity: 40 | Color: Yellow (RGB 255,255,0)
LED 4:
  • Starting Value: 5500 | Intensity: 0 | Color: Orange (RGB 255,126,0)
  • Ending Value : 6499 | Intensity: 40 | Color: Orange (RGB 255,126,0)
LED 5:
  • Starting Value: 6500 | Intensity: 0 | Color: Red (RGB 255,0,0)
  • Ending Value: 7000 | Intensity: 40 | Color: Red (RGB 255,0,0)
mfwalsh942
Matthew
Columbus, Georgia
2019 Honda Civic Sport Hatchback
For those who use the K Tuner V2 unit while driving, (I ordered a mount for it) what is your favorite layout and what kind of data do you choose to display? Thanks!
hobby-man
GTA
2021 WRX STi, 2018 Sport Touring Hatchback (sold)
@knadsady I see you figured it out on your own ;)
I use the 11 item gauge with the tach/gear readout in the center. Most information possible. Use IAT1/2, ECT1/2, MAP, KCON, AFR, TPS, TPC, STFT, LTFT.
mfwalsh942
Matthew
Columbus, Georgia
I did, sort of. I set up with the same layout, my readouts are very slightly different, but now that I know how to manipulate them, I can play with it a little until I get it just the way I like it. Thanks!
viciousknish
Jonathan
New Hampshire
1996 Civic Ex Coupe, 2007 Civic Si Sedan, 2020 Civic Si Sedan
@knadsady I took your LED setup and tweaked it a bit to take into account the fuel cutoff when you hit redline at 6500. You get an early warning at 6300 RPM and a slight shift in the colors.
All, I made one template with a Green, yellow, orange, and red swipe shown below and one that is all red but same functionality. Attached is a .zip file with the two templates or you can grab them from my OneDrive. : https://1drv.ms/u/s!BN5M1NMzYHJVg-sl_EFlHIv_1rywsA?e=TcdYsC
Settings:
  • Type: RPM
All LEDs:
  • Warning Value: 6300 | Intensity: 70 | Color: Red (RGB 255,0,0)
  • Cutoff Value: 0
LED 1:
  • Starting Value: 2000 | Intensity: 0 | Color: Green (RGB 0,255,0)
  • Ending Value : 2999 | Intensity: 40 | Color: Green (RGB 0,255,0)
LED 2:
  • Starting Value: 3000 | Intensity: 0 | Color: Yellow (RGB 255,255,0)
  • Ending Value : 3999 | Intensity: 40 | Color: Yellow (RGB 255,255,0)
LED 3:
  • Starting Value: 4000 | Intensity: 0 | Color: Orange (RGB 255,126,0)
  • Ending Value : 4999 | Intensity: 40 | Color: Orange (RGB 255,126,0)
LED 4:
  • Starting Value: 5000 | Intensity: 0 | Color: Redish-Orange (RGB 255,63,0)
  • Ending Value : 5999 | Intensity: 40 | Color: Redish-Orange (RGB 255,63,0)
LED 5:
  • Starting Value: 6000 | Intensity: 0 | Color: Red (RGB 255,0,0)
  • Ending Value: 6299 | Intensity: 40 | Color: Red (RGB 255,0,0)
JD9
2018 Honda Civic Si Coupe
Here is the shift light/RPM warning I set up. Just got my Ktuner V2 yesterday :)
I can post details if anybody wants to copy
Please post details, yours looks great!
