Front Lift Point Dented/Collapsed
cryptolime
Wilmington, NC
2023 Civic Si
After doing a couple oil changes and installing a RMM i noticed the front lift point appears to be dented/collapsed inward. Can this effect alignment in anyway? Is it designed to collapse a bit after a lot of use? I used a thick rubber jack pad and always made sure it was centered on the lift point but still appears to be dented inward. Thoughts? Anyone else notice any denting in this area?
Also found a good pic of the subframe. It appears there's two different types of metal on the subframe. I guess the silver metal is high strength steel and black part visible from the bottom is aluminum?
11th Gen Honda Civic Front Lift Point Dented/Collapsed IMG_2374
11th Gen Honda Civic Front Lift Point Dented/Collapsed IMG_2371
11th Gen Honda Civic Front Lift Point Dented/Collapsed civicsubframe2
11th Gen Honda Civic Front Lift Point Dented/Collapsed civicsubframe1
