vaskaskh
Hello,
For a few weeks now, I’ve been experiencing a strange vibration coming from the left side of the car. I had the wheels aligned perfectly, so I initially ruled that out. Today, I suspected the left rim might be slightly bent or out of balance, but after checking, I found no issues there. However, the noise still persists.
I don’t feel any vibration through the steering wheel — it just seems to come from the driver’s front left side.
Do you have any suggestions or have you experienced something similar?
I'm starting to suspect the inner tie rod. When I built the car, it was very slightly bent, and I bent it back into shape, since there’s a big shortage of FL5 parts in my country. However, the alignment didn’t show any problems. Could that still be the cause?
At low speeds, the issue is not noticeable. It usually starts around 40–60 km/h and continues at higher speeds. The sound is noticeable, but while driving, you don’t feel it anywhere (not even on the steering wheel) — it’s just an irritating noise.
!!! It feels similar to driving over a painted road line
When I took off the wheel, I noticed that the inner side of the tire was slightly more worn than the outer side.
any suggestions?
any suggestions?
